Analyzers
Help, VTune 2015 profile collection failed in x86 android
Naux_F_
Help,
       I used Vtune2015 to profile an android project. It failed just after I attached project process ID. I attached the screen print. Has anyone known this?.
Peter_W_Intel
I don't know detail on Android, I had an old example of using VTune to profile Java process from Apache-tomcat but it was not in embedded environment.
Please post your questions about using tools in embedded system to this forum.
William_B_Intel1
What type of analysis and what device were you attempting to profile?
I've occasionally gotten some failures from a flaky USB connection or other irregular reason where simply trying again works great.  From the text of your included error message however it looks like you've got a corrupted system build image, or are running on non-Intel device.
Naux_F_
Thx for yout reply. Type is basic hotspot analysis. The profile is run on Dell Venue 8 7840 and the version of android is 4.4.4.
Kirill_U_Intel
Looks like known android issue with run-as.
Could you check output from 'adb shell run-as com.intel.vtune id; pm path com.intel.vtune'?
if it is like below then basic hotspots will not be available
output:
run-as: Package 'com.intel.vtune' is unknown
package:/data/app/com.intel.vtune-1.apk
BTW, is it possible root your device? Rooting should fix basic hotspots abd provide advanced-hotspots collections.
http://opensource.dell.com/releases/Venue_8_7840_Merrifield/developer-edition/
Kirill
Naux_F_
Hi, Kirill. I typed the command and the output result is the same as you guessed. By the way, is there any instruction for root Venue_8_7840?
output:
Kirill_U_Intel
output:
the link should include pdf instructions and needed flash files
