Analyzers
5340 Discussions
How to find a function by name?
fmunkert
It seems like an absolute beginner's question, but I have found no way to do that, even after studying the online help:
In the top-down tree of a hotspot analysis of Amplifier XE 2011, how can you search for a function by its name?
Many thanks in advance for any helpful hints.
- Frank
Peter_W_Intel
If you have a BIG tree for "Top-down tree" report, it is hard to look for specific function.
I suggest to use "Bottom-up" report, all functions will be listed, so you can click on "/Function/Call Stack" (for example) to sort items by function name.
Regards, Peter
fmunkert
Searching in the "Bottom-up" pane does not help me, because this pane seems to list only functions that have some mininimum "self time". The function that I am searching, however, as almost no "self time"; it are the childrens and grandchildrens of that function which contribute time.
- Frank
Peter_W_Intel
If your function has no "self time", it will not be in the list of "Bottom-up". There is no idea to search the function (caller) which has childrens (grandchildren) to contribute CPU time. Sorry!
Regards, Peter
