Analyzers
5255 Discussions
How to find source code location of the hotspot for O2 on MIC?
King_Crimson
Dear experts,
My question is about using vtune (Amplifier XE 2016 Update 2 (build 444464)) to profile C++ code on MICs.
I was trying to find the top 5 functions with largest CPU_CLK_UNHALTED values and pinpoint the lines of source code causing the hotspots. When using -g -O0, vtune was able to find the functions' name and display the source, but when switching to -g -O2, apparently I could not find those functions' name any more and, instead of the source code, only the assembly was available. Why?
Is it because the compiler has inlined functions wherever possible and somehow stripped the debug info even if -g is present? Is there a way to show which line of source code the assembly belongs to?
Thanks for any advice.
Denis_M_Intel
It is not expected.
- If you run a native MIC application and have a Linux system, it is possible to use the addr2line Linux utility to check that your application has source line information.
- It would be helpful to check VTune finalization output and see if there are any warnings related to your application.
- try to add the directory where the application binary is located to the binary search paths (-search-dir option in cli) and re-resolve the result.
- Is it reproducible with other MIC applications like 'matrix' from VTune samples? If that is the case, could you attach VTune result directory and the corresponding binary file?
Denis_M_Intel
It is not expected.
King_Crimson
I added binary search paths and the names are now resolved correctly. Thanks.
King_Crimson
I have a follow-up question. I my custom profiling analysis, vtune seems to have ignored some metrics and do not report the values in the Caller/Callee page, although the metrics' name indeed appear in the Analysis Type panel.
L1_DATA_HIT_INFLIGHT_PF1
L2_DATA_READ_MISS_CACHE_FILL
DATA_PAGE_WALK
LONG_DATA_PAGE_WALK
L2_VICTIM_REQ_WITH_DATA
SNP_HITM_L2
How to solve this issue? Is this related to any of the warnings below, such as the first two pieces?
Thank for your comments.
Dmitry_P_Intel1
For custom event analysis by default VTune uses HW Events viewpoint that simply shows event values on summary and grid views including caller/callee. First of all - if you look at summary pane - do you see all the events that you set in hardware events table?
Thanks & Regards, Dmitry
