Analyzers
5255 Discussions
How to use VTUNE Remote SSH through gateway
gasor
I’m trying to set up a Remote SSH connection to my server using VTune. The server is only reachable through a gateway, but I haven’t been able to get it working.
Here’s what I’ve tried so far:
  1. Updated my .ssh/config to use a ProxyJump — VTune just opens and closes a command window in a loop.
  2. Tried using the ssh -J option — also doesn’t work with VTune.
  3. Created an SSH tunnel and attempted to connect VTune to localhost, but it seems VTune doesn’t handle the -p option properly.
Is there a supported way to do this, or is it not possible to use VTune through a gateway?
Thanks in advance!
optimizergal
I've seen something similar when using netcat, where it opens a bunch of command windows. But it eventually gets there.
When you enter a hostname into VTune, it creates its own ssh key stored in user/.ssh and then tries to copy it to the remote system. One of the command prompts will ask you enter a password, and this can get buried. You can configure it to use your own key, and there's an example of how to do that here:
https://www.intel.com/content/www/us/en/docs/vtune-profiler/cookbook/2025-4/profiling-applications-in-aws-ec2-instances.html
If it still doesn't work, you can try using VTune server. With that, you basically install VTune on the remote system and start a web service so you can use VTune on your local browser. I'm not a network expert so if you need to set up more than basic security then I can't really help.
https://www.intel.com/content/www/us/en/docs/vtune-profiler/cookbook/2025-4/viewing-analysis-results-on-web-browser.html
