Analyzers
I try to use hardware sampling event to calculate the L1,L2 miss, but it says that" unable to open shared library:libivytown.so
sun_s_
I try to use hardware sampling event to calculate the L1,L2 miss.
I use the command" amplxe-cl -collect-with runsa -knob event-config=MEM_LOAD_UPOS_RETIRED.LLC_HIT_PS,  MEM_LOAD_UOPS_LLC_HIT_RETIRED.XSNP_HIT_PS, MEM_LOAD_UOPS_LLC_HIT_RETIRED.XSNP_HITM_PS,CPU_CLK_UNHALTED.THREAD /home/test"
but it fails saying that "osi_DLL_ERROR:libivytown.so:cannot open shared object file:no such file or directory
  unable to open shared library :libivytown.so".
My machine is Ivybridge E5-2692v2. Using "amplxe-cl -collect hotspots" command is successful.
I have no idea about what the error means. Is there any thing wrong with my library file?
Any help would be appreciated.
David_A_Intel1
This indicates that you are using a newly released processor for which support has not been made publicly available, yet.  The next update of VTune(TM) Amplifier XE 2013 should include this support.  Watch for the update information in the Registration Center and Intel(R) Software Update Manager.
David_A_Intel1
sun_s_
@MrAnderson (Intel)
Thanks a lot. I'll watch for the update information.
However, while I turn to use a sandybridge microarchitecture, I encounter 2 problems when I try to use the formula given by @ Kirill Rogozhin (Intel) to  calculate the cache miss.
1.When I calculate the L3 miss ratio, I get 90%. But my test application code is just one line using function printf. Therefore , it can't be that
   big. And when I calculate the L2 miss ration, the result is even bigger than 1 which is obvious not correct.
2.When I use hardware event :MEM_LOAD_RETIRED.LLC_HIT_PS , it shows that it's a invalid event. But on the platform of Sandybridge,
I think this event should be valid. So, I've no idea what's happening.
Sun.
David_A_Intel1
Hi sun:
I'm sorry.  I can't help you with that.  I just use the tool.  We already have everything defined in the General Exploration analysis type.  All micrprocessor issues are defined and identified via this analysis type, so I never calculate my own. :\
If you review our tuning guides, you will see that the General Exploration analysis type correlates directly to the tuning guides.  I highly recommend you follow these guides and the advise we provide via them.
