Analyzers
5256 Discussions
Inspector XE ( Parallel Studio XE for Linux 12.0.4 )
bernaske
we work with the Parallel Studio XE Version 12.0 (update 2 ) on openSUSE 12.1 Milestone 1 ( M1 ), also on openSUSE 11.4 GM all 64 Bit Releases, all works fine, actual we have change to the new Linux Kernel 3.0 , all components work fine with one exception the
inspector XE does not works correct, in the logs means the problem are the not supported linux 3.0 Kernel, comes maybe a fix
for the kernel 3.0, i like the Kernel 3.0
thanks for all
best regards
Franz Bernasek 'bernaske'
Peter_W_Intel
As I know that latest Inspector XE Update 4 hasn't been tested (supported) on new Linux* kernel 3.0 platform.
Linux* kernel version 3.0might be considered to be supported, in future releases, in my view.
Regards, Peter
bernaske
Hi, Peter
thanks for th information
regards
Franz
