Analyzers
5315 Discussions
Inspector does not let my program read external files.
dominique120
I have a program that must read a configuration file when it starts but whenever I start this program inside inspector the program does not read this external configuration file. If I execute the program outside of Inspector the program loads this file fine.
Is these something I can do so that my program reads the config file?
Peter_W_Intel
It sounds this is impossible.
On GUI, have you added items into "User-defined environment variables" which is in <Project Properties>\Target tab ? These user environment variables might be required for program to read external files.
Another way is, use a console which can ran your app to read external files, without Inspector XE. Then run inspxe-gui or inspxe-cl, they will inherit all system variables and user variables from this console.
Peter_W_Intel
dominique120
I did not adjust the env variables but I did adjust other options like the working directory.
Everything is working now, thank you.
Peter_W_Intel
 Yes. Run Inspector from console which has right working directory, will help. Thank you let me know the problem has been solved:-)
dominique120
I'm having the same problems with Advisor but I cant fix it with the console and I dont see any properties windows, what should I do?
Peter_W_Intel
Please go this forum to discuss the problem from Advisor XE.
