Analyzers
5338 Discussions
Installation problems
Paweł_J_
Hello all,
I have a strange problem with installation of Intel® Inspector XE. I've downloaded Parallel Studio XE 2015 update 1 setup trial version. The extracting files went well, but when I run setup from directory C:\Program Files (x86)\Intel\Download\parallel_studio_xe_2015_update1_setup I can see only a splashscreen and after few seconds it disappear. In task manager I also can see "setup.exe *32"  process for few seconds and then it disappear. Nothing else is done. I use windows 7. My computer is IntelCore i7 960 with 4GB RAM. I also downloaded Intel® System Studio 2015, but the situation is the same. I downloaded both version online installation and offline the same effect. Thanks for any help!
Peter_W_Intel
Probably you installed prior version - you need to uninstall it first then install new version.
Can you download Inspector XE 2015, then run Inspector_XE_2015_update1_setup.exe as administrator?
