- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I have test cases in my Visual Studio 2019 solution. It is run by Visual studio by calling the vstest.console.exe. Now I need to check memory leak by running these test cases. Not able to do that using Intel Inspector.
Inputs given by me in Project properties are:
Application: C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\Common7\IDE\Extensions\TestPlatform\vstest.console.exe
Application parameters: /testcontainer:TwoOPT_TestSuite_x64.dll
Working directory: C:\Projects\TwoOPT\Code\bin\x64\Debug (same which have TwoOPT_TestSuite_x64.dll)
I get error:
Error: Analysis terminated abnormally.
Application exit code: -1
Please let me know what mistake I am doing in providing inputs in project properties. Thanks.
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Could you provide test app for local reproducing?
Please provide Inspector version you used. Thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thank you for your response. The installer used was w_inspector_oneapi_p_2023.0.0.25545.exe
The attached images shows the error message and details.
Please provide guidance in troubleshooting the failure. Thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Did you try with one simple sample, like matrix sample, you can see, the below matrix sample is run by VS in local, and the Inspector can work.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Yes, it works. I created another new console application and giving the path to this console application also works.
What I am struggling is to run the Intel Inspector for VSTest.Console.exe which is the command-line tool to run tests. The details on this exe is https://learn.microsoft.com/en-us/visualstudio/test/vstest-console-options?view=vs-2022
I guess I am not properly giving the inputs in Application parameters in Intel Inspector project properties. Any help in this will be really helpful.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Just running application with parameters as below can work?
C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\Common7\IDE\Extensions\TestPlatform\vstest.console.exe /testcontainer:TwoOPT_TestSuite_x64.dll
From the guide you shared, there is no need to add '/' , just needs file name, right?
vstest.console.exe myTestProject.dll
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Tried the following but doesn't work.
1.
2.
Application parameters: TwoOPT_TestSuite_x64.dll
3.
Application: C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\Common7\IDE\Extensions\TestPlatform\vstest.console.exe /testcontainer:TwoOPT_TestSuite_x64.dll
4.
Application: C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\Common7\IDE\Extensions\TestPlatform\vstest.console.exe TwoOPT_TestSuite_x64.dll
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
So I think you need to confirm app + parameters can work first, and then using Inspector to run app + parameters.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks for your reply. Sorry, didn't understand. app + parameters in the Application: field?
or something else.
The gist of the problem is that when I run console application and call the exe vstest.console.exe with parameters /testcontainer:TwoOPT_TestSuite_x64.dll, it works.
But if I provide them as below to Intel Inspector, it doesn't work.
I will check some more documentation, meanwhile any more pointers from anyone will be helpful.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
You can add "vstest.console.exe /testcontainer:TwoOPT_TestSuite_x64.dll" in one script and specify the script to execute in the application field.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
