- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
I try to use Intel Thread Checker but can't check even samples. Then I try to folow getting started guide and perform "tcheck_cl ./primes.gcc" Thread Checker hungs just after two strings:
"Intel Thread Checker 3.1 command line instrumentation driver (27583)
Copyright (c) 2007 Intel Corporation. All rights reserved."
I use Intel Thread Checker 3.1_012 for Linux. Operating system is Ubuntu 8.10 server clear setup. Cpu is Intel Core Duo E2160
1 Soluzione
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Quoting - hitfounder
I had the same problem, and it was solved by using the "--noinstrument" flag with tcheck_cl.
Hope this helps.
Link copiato
5 Risposte
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
By the way, have you done "source /opt/intel/itt/tchecker/bin/32(e)/tcheck_vars.sh" before running tcheck_cl?
Regards, Peter
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hope this helps.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Quoting - ymost
Hope this helps.
Thanks a lot, it helps.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Quoting - ymost
But this option switches off the binary instrumentation of Thread Chacker, which means you won't collect useful results. In this case youmight want to use source level instrumentation (-tcheck option)during compilation with Intel compiler.
Rispondere
Opzioni discussione
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
