Analyzers
5342 Discussions
Intel VTune for Embedded Windows OS
Giorgio_S_
Hi all,
I am wondering if it is possible to use VTune 2013 or VTune2015 using Windows embedded and, if yes, what is the minimum supported windows edition. I read on the release notes that "embedded editions not supported" but I would like to know if there is a way for example to collect data on an embedded system and view results on standard windows system and/or to perform remote mode using Windows embedded target.
Giorgio
Peter_W_Intel
Please go https://premier.intel.com to submit your feature request.
If your embedded system has no disk space restricted, you can extract VTune Amplifier XE package (e.g. "VTune_Amplifier_XE_2015_setup.exe --extract-only --silent --extract-folder C:\temp\VTune_Amplifier_XE_2015_unpacked") then install it (e.g. run "Amplifier_XE.msi" with Administrative privileges) on the target.
vtune drivers might or might not work, user-mode sampling collection can work I guess. Note that your target system hasn't been tested and have no technical support for now, it is your risk to run this product on unsupported operation system.
