I started to get crashes regularly in phase where VTune tries to resolve symbols.
It happened after I updated my system, so maybe I suspect some conflict within environment.
WHat I tried:
a) repair and reinstall w_oneapi_vtune_p_2024.1.0.520_offline
b) downgrade VTune to w_oneapi_vtune_p_2024.0.1.13_offline.exe
c) clean up local symbols cache completely (to avoid problems with corrupted symbols)
Nothing helped.
[Exception]
Address: 0x00007ff98b5c19e7
Code: 0x00000000c0000005
CrashedPID: 25224
CrashedTID: 7092
Description: EXCEPTION_ACCESS_VIOLATION
Module: amplxe_msdia140.dll
Product: Intel(R) VTune(TM) Profiler 2024.0.1; 627177
ReportPath: C:\Users\Lukas\AppData\Local\Temp\amplxe-log-Lukas\2024-05-07-18-38-55-719.vtune-worker.exe\
[Process]
Process Name: vtune-worker.exe
Virtual Memory Size: 6100240K
Working Set Size: 1484552K
[Products]
Package ID: N/A
Package Contents: Intel(R) VTune(TM) Profiler 2024.0.1
Build Number: 627177
[PremortalLog]
334 [22232] ERROR cfgmgr <> - (outputBag != 0) && (inputBag != 0) && !m_ctx.is_null() 'gh2::error::FailedTo.Process.The.Parameter:'
vcs\cfgmgr2\src\rules.cpp(2020): process
, at file: vcs\cfgmgr2\src\rules.cpp:2020
367 [22232] ERROR cfgmgr <> - Errors happened during transformation
367 [22232] ERROR cfgmgr <> - %ThisAnalysisTypeIsNotApplicable
372 [22232] ERROR cfgmgr <> - Errors happened during transformation
372 [22232] ERROR cfgmgr <> - %ThisAnalysisTypeIsOnlyForLinux
377 [22232] ERROR cfgmgr <> - Errors happened during transformation
377 [22232] ERROR cfgmgr <> - %ThisAnalysisTypeIsNotApplicable
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuL3SamplerThroughputAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuL3ShaderThroughputAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuL3_BYTE_READAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuL3_BYTE_WRITEAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuUntypedBytesReadAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuUntypedBytesWrittenAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSlmBytesReadAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSlmBytesWrittenAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuTypedBytesReadAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuTypedBytesWrittenAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuGtiReadThroughputAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuGtiWriteThroughputAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuGtiL3ThroughputAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuHOST_TO_GPUMEM_BYTE_READAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuHOST_TO_GPUMEM_BYTE_WRITEAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSYSMEM_BYTE_READAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSYSMEM_BYTE_WRITEAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSTACK_TO_STACK_RECEIVEAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSTACK_TO_STACK_TRANSMITAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2251 [22232] ERROR dbinterface <> - addColumnV2(): Can't resolve (gpu_data, __bucket_idx): root table is not valid, at file: vcs\dbinterface1\src\sqlite\query.cpp:308
2251 [22232] ERROR dbiproviders <> - bucketIdx != dbi1::InvalidColIdx
vcs\dbiproviders1\src\rule_helpers.cpp(682): call
, at file: vcs\dbiproviders1\src\rule_helpers.cpp:682
2899 [22232] ERROR dicerresolver <> - gh2::is_success(err)
vcs\dicerresolver2\src\impl\resolver_impl.cpp(4593): load_settings
, at file: vcs\dicerresolver2\src\impl\resolver_impl.cpp:4593
Any suggestions what could help?
Could you post the command line and attach the log file?
I execute the Intel VTune directly from MSVC IDE through the UI integration. I don't know the command line.
command.txt contains:
C:\Program Files (x86)\Intel\oneAPI\vtune\2024.0\bin64
Windows 11:
OS Name: Microsoft Windows 11 Pro
OS Version: 10.0.22631 N/A Build 22631
Log is attached.
Is the issue observed only from MSVC? Did you reproduce the issue from VTune directly?
Yes, also reproducible directly from the VTune GUI:
Did you try to attach one simple process instead of the current process? Please attach the VTune data.
I'm able to profile c:\Qt\5.15.2\msvc2019_64\bin\qdbusviewer.exe just fine for example:
The Intel VTune symbol resolution process crashes only for our proprietary project.
Could you post the command line copied from the VTune GUI below? Please attach the VTune data if possible.
Hm...the bug is gone. I cannot reproduce it anymore.
I recalled I added symbols for nvidia recently:
https://driver-symbols.nvidia.com/
but when I added it back it still does not crash.
Command-line:
"C:\Program Files (x86)\Intel\oneAPI\vtune\2024.0\bin64\vtune" -collect hotspots --app-working-dir=V:\build\product\ -- V:\build\product\bin\RelWithDebInfo\Milo-Product.exe
Not sure what happened, but the crash is not reproducible, I can profile again.
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
