Analyzers
5250 Discussions
Intel VTune started to crash: gh2::error::FailedTo.Process.The.Paramet
LukasT
I started to get crashes regularly in phase where VTune tries to resolve symbols.
It happened after I updated my system, so maybe I suspect some conflict within environment.
WHat I tried:
a) repair and reinstall w_oneapi_vtune_p_2024.1.0.520_offline
b) downgrade VTune to w_oneapi_vtune_p_2024.0.1.13_offline.exe
c) clean up local symbols cache completely (to avoid problems with corrupted symbols)
Nothing helped.
[Exception]
Address: 0x00007ff98b5c19e7
Code: 0x00000000c0000005
CrashedPID: 25224
CrashedTID: 7092
Description: EXCEPTION_ACCESS_VIOLATION
Module: amplxe_msdia140.dll
Product: Intel(R) VTune(TM) Profiler 2024.0.1; 627177
ReportPath: C:\Users\Lukas\AppData\Local\Temp\amplxe-log-Lukas\2024-05-07-18-38-55-719.vtune-worker.exe\
[Process]
Process Name: vtune-worker.exe
Virtual Memory Size: 6100240K
Working Set Size: 1484552K
[Products]
Package ID: N/A
Package Contents: Intel(R) VTune(TM) Profiler 2024.0.1
Build Number: 627177
[PremortalLog]
334 [22232] ERROR cfgmgr <> - (outputBag != 0) && (inputBag != 0) && !m_ctx.is_null() 'gh2::error::FailedTo.Process.The.Parameter:'
vcs\cfgmgr2\src\rules.cpp(2020): process
, at file: vcs\cfgmgr2\src\rules.cpp:2020
367 [22232] ERROR cfgmgr <> - Errors happened during transformation
367 [22232] ERROR cfgmgr <> - %ThisAnalysisTypeIsNotApplicable
372 [22232] ERROR cfgmgr <> - Errors happened during transformation
372 [22232] ERROR cfgmgr <> - %ThisAnalysisTypeIsOnlyForLinux
377 [22232] ERROR cfgmgr <> - Errors happened during transformation
377 [22232] ERROR cfgmgr <> - %ThisAnalysisTypeIsNotApplicable
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuL3SamplerThroughputAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuL3ShaderThroughputAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuL3_BYTE_READAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuL3_BYTE_WRITEAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuUntypedBytesReadAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuUntypedBytesWrittenAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSlmBytesReadAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSlmBytesWrittenAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuTypedBytesReadAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuTypedBytesWrittenAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuGtiReadThroughputAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuGtiWriteThroughputAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuGtiL3ThroughputAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuHOST_TO_GPUMEM_BYTE_READAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuHOST_TO_GPUMEM_BYTE_WRITEAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSYSMEM_BYTE_READAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSYSMEM_BYTE_WRITEAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSTACK_TO_STACK_RECEIVEAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2250 [22232] ERROR cfgmgr <> - Cannot find context value: gpuSTACK_TO_STACK_TRANSMITAbsMaxValue., at file: vcs\cfgmgr2\src\rules.cpp:377
2251 [22232] ERROR dbinterface <> - addColumnV2(): Can't resolve (gpu_data, __bucket_idx): root table is not valid, at file: vcs\dbinterface1\src\sqlite\query.cpp:308
2251 [22232] ERROR dbiproviders <> - bucketIdx != dbi1::InvalidColIdx
vcs\dbiproviders1\src\rule_helpers.cpp(682): call
, at file: vcs\dbiproviders1\src\rule_helpers.cpp:682
2899 [22232] ERROR dicerresolver <> - gh2::is_success(err)
vcs\dicerresolver2\src\impl\resolver_impl.cpp(4593): load_settings
, at file: vcs\dicerresolver2\src\impl\resolver_impl.cpp:4593
Any suggestions what could help?
yuzhang3_intel
Could you post the command line and attach the log file?
LukasT
I execute the Intel VTune directly from MSVC IDE through the UI integration. I don't know the command line.
command.txt contains:
C:\Program Files (x86)\Intel\oneAPI\vtune\2024.0\bin64
Windows 11:
OS Name: Microsoft Windows 11 Pro
OS Version: 10.0.22631 N/A Build 22631
Log is attached.
yuzhang3_intel
Is the issue observed only from MSVC? Did you reproduce the issue from VTune directly?
LukasT
Yes, also reproducible directly from the VTune GUI:
yuzhang3_intel
Did you try to attach one simple process instead of the current process? Please attach the VTune data.
LukasT
I'm able to profile c:\Qt\5.15.2\msvc2019_64\bin\qdbusviewer.exe just fine for example:
The Intel VTune symbol resolution process crashes only for our proprietary project.
yuzhang3_intel
Could you post the command line copied from the VTune GUI below? Please attach the VTune data if possible.
LukasT
Hm...the bug is gone. I cannot reproduce it anymore.
I recalled I added symbols for nvidia recently:
https://driver-symbols.nvidia.com/
but when I added it back it still does not crash.
Command-line:
"C:\Program Files (x86)\Intel\oneAPI\vtune\2024.0\bin64\vtune" -collect hotspots --app-working-dir=V:\build\product\ -- V:\build\product\bin\RelWithDebInfo\Milo-Product.exe
Not sure what happened, but the crash is not reproducible, I can profile again.
