Analyzers
5250 Discussions
Intermittent segfault when finalizing results
Jason_L_2
I encounter an intermittent segfault when finalizing results from a hotspot analysis. I identified that the segfault only occurs if ~/.flexlmborrow exists as a result of borrowing a floating license via "lmutil lmborrow all 30-Sep-2016 18:46". When ~/.flexlmborrow exists, the segfault occurs roughly four out of every five attempts.
I perform the analysis with this command (no issues with this stage so long as I include the -no-auto-finalize flag, if I attempt to finalize as part of this command I see the same failure):
$ amplxe-cl -collect hotspots -knob sampling-interval=1 -target-duration-type=veryshort -no-auto-finalize -app-working-dir . -- /path/to/my/app
I attempt to finalize the results with this command:
$ amplxe-cl -finalize -r r000hs
I can successfully run the finalize command every time after deleting ~/.flexlmborrow.
Here is the output from the above command when it fails:
amplxe: Using result path `/media/nvme4/performance/WriteTest_256x256x256_none/r000hs'
amplxe: Executing actions 39 % Resolving information for `libdl.so.2'
amplxe: Warning: Cannot locate debugging symbols for file `/lib64/libdl.so.2'.
amplxe: Warning: Cannot locate debugging symbols for file `/lib64/libgcc_s.so.1'.
amplxe: Executing actions 39 % Resolving information for `libpthread.so.0'
amplxe: Warning: Cannot locate debugging symbols for file `/lib64/libstdc++.so.6'.
amplxe: Executing actions 39 % Resolving information for `libtbb.so.2'
amplxe: Warning: Cannot locate debugging symbols for file `/lib64/libpthread.so.0'.
amplxe: Executing actions 39 % Resolving information for `pinbin'
amplxe: Warning: Cannot locate debugging symbols for file `/lib64/libc.so.6'.
amplxe: Executing actions 39 % Resolving information for `libtbb_debug.so.2'
amplxe: Warning: Cannot locate debugging symbols for file `/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/pinbin'.
amplxe: Executing actions 40 % Resolving information for `libittnotify_collecto
amplxe: Warning: Cannot locate debugging symbols for file `/opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/runtime/libittnotify_collector.so'.
amplxe: Executing actions 41 % Resolving information for `libtpsstool.so'
amplxe: Warning: Cannot locate debugging symbols for file `/opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libtpsstool.so'.
amplxe: Executing actions 42 % Resolving information for `ld-linux-x86-64.so.2'
amplxe: Warning: Cannot locate debugging symbols for file `/lib64/ld-linux-x86-64.so.2'.
amplxe: Executing actions 43 % Resolving information for `libc-dynamic.so'
amplxe: Warning: Cannot locate debugging symbols for file `/opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/pinruntime/libc-dynamic.so'.
amplxe: Executing actions 100 % done
Intel(R) VTune(TM) Amplifier XE 2017 (build 478468) feedback tool
Copyright (C) 2009-2016 Intel Corporation. All rights reserved.
Intel(R) VTune(TM) Amplifier XE 2017; 478468 experienced an unexpected error.
Please send a problem report:
amplxe-feedback --send-crash-report "/tmp/amplxe-log-jason/2016-09-29-18-53-56-760988.amplxe-cl/crash_info.txt"
Report data may be used to improve product stability. Our apologies for the inconvenience and thank you for your assistance.
Exception: 0xb, Segmentation fault
Module: libc-2.17.so
Collecting modules information...
Collecting system information...
Aborted
I ran the finalize command through gdb and observed a few different failure scenarios:
$ gdb-ia amplxe-cl
GNU gdb (GDB) 7.10-18.0.336
Copyright (C) 2015 Free Software Foundation, Inc; (C) 2016 Intel Corp.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-unknown-linux-gnu".
Type "show configuration" for configuration details.
For information about how to find Technical Support, Product Updates,
User Forums, FAQs, tips and tricks, and other support information, please visit:
<http://www.intel.com/software/products/support/>.For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from amplxe-cl...(no debugging symbols found)...done.
(gdb) r -finalize -r r002hs
The program being debugged has been started already.
Start it from the beginning? (y or n) y
Starting program: /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/amplxe-cl -finalize -r r002hs
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
[New Thread 0x7fffe90d7700 (LWP 76291)]
amplxe: Using result path `/media/nvme4/performance/WriteTest_256x256x256_none/r002hs'
[New Thread 0x7fffe175d700 (LWP 76297)]
[New Thread 0x7fffe135c700 (LWP 76298)]
[New Thread 0x7fffe0f5b700 (LWP 76299)]
[New Thread 0x7fffe0759700 (LWP 76300)]
[New Thread 0x7fffe0b5a700 (LWP 76301)]
[New Thread 0x7fffdbfff700 (LWP 76302)]
[New Thread 0x7fffdbbfe700 (LWP 76303)]
amplxe: Executing actions 39 % Resolving information for `libstdc++.so.6'
amplxe: Executing actions 40 % Resolving information for `libtpsstool.so'
amplxe: Executing actions 40 % Resolving information for `libdl.so.2'
amplxe: Executing actions 40 % Resolving information for `libtbbmalloc.so.2'
amplxe: Executing actions 40 % Resolving information for `libpin3dwarf.so'
amplxe: Warning: Cannot locate debugging symbols for file `/opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/pinruntime/libpin3dwarf.so'.
amplxe: Executing actions 41 % Resolving information for `libtbb_preview_debug.
amplxe: Executing actions 43 % Resolving information for `libpthread.so.0'
[Thread 0x7fffe0f5b700 (LWP 76299) exited]
[Thread 0x7fffdbbfe700 (LWP 76303) exited]
[Thread 0x7fffe135c700 (LWP 76298) exited]
[Thread 0x7fffe175d700 (LWP 76297) exited]
[Thread 0x7fffe0b5a700 (LWP 76301) exited]
[Thread 0x7fffdbfff700 (LWP 76302) exited]
[Thread 0x7fffe0759700 (LWP 76300) exited]
warning: Cannot parse .gnu_debugdata section; LZMA support was disabled at compile time
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff16103c1 in __strlen_sse2_pminub () from /lib64/libc.so.6
(gdb) bt
#0  0x00007ffff16103c1 in __strlen_sse2_pminub () from /lib64/libc.so.6
#1  0x00007ffff1b4b971 in std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&) ()
   from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/libstdc++.so.6
#2  0x00007fffeff42851 in ivbm2_2_6::license::query_license_info() () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#3  0x00007fffeff4a24b in ivbm2_2_6::license::acquire_internal(std::vector<std::string, std::allocator<std::string> > const&) ()
#4  0x00007fffeff4afe6 in ivbm2_2_6::license::default_acquire(ivbm2_2_6::license::ui_mode_type const&, std::string const&) ()
#5  0x00007ffff3902b29 in featurestat_1_3_3::license_info_provider_impl_t::license_info_provider_impl_t() ()
   from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/libamplxe_featurestat_core_1.3.so
#6  0x00007ffff3938b84 in featurestat_1_3_3::statistic_t::get() () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/libamplxe_featurestat_core_1.3.so
#7  0x0000000000412704 in ?? ()
#8  0x00007ffff14ceb15 in __libc_start_main () from /lib64/libc.so.6
#9  0x0000000000406c59 in ?? ()
#10 0x00007fffffffc988 in ?? ()
#11 0x000000000000001c in ?? ()
#12 0x0000000000000004 in ?? ()
#13 0x00007fffffffcdb7 in ?? ()
#14 0x00007fffffffcdf5 in ?? ()
#15 0x00007fffffffcdff in ?? ()
#16 0x00007fffffffce02 in ?? ()
#17 0x0000000000000000 in ?? ()
[New Thread 0x7fffe90d7700 (LWP 76401)]
[New Thread 0x7fffe175d700 (LWP 76403)]
[New Thread 0x7fffe0f5b700 (LWP 76405)]
[New Thread 0x7fffe135c700 (LWP 76404)]
[New Thread 0x7fffe0759700 (LWP 76407)]
[New Thread 0x7fffe0b5a700 (LWP 76406)]
[New Thread 0x7fffd3fff700 (LWP 76408)]
[New Thread 0x7fffd3bfe700 (LWP 76409)]
amplxe: Executing actions  0 %
0x00007fffeff3be59 in ?? () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
(gdb) bt
#0  0x00007fffeff3be59 in ?? () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#1  0x00007fffeff3bffc in ?? () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#2  0x00007fffeff3ccbc in flex_kwd_search () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#3  0x00007fffeff40029 in checkout_license(char const*, unsigned int, int, int, int, int, char const*) ()
#4  0x00007fffeff40ccb in flex_checkout_license () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#5  0x00007fffeff4338f in ivbm2_2_6::license::checkout_internal(std::vector<std::string, std::allocator<std::string> > const&) ()
#6  0x00007fffeff49c93 in ivbm2_2_6::license::acquire_internal(std::vector<std::string, std::allocator<std::string> > const&) ()
#7  0x00007fffeff4afe6 in ivbm2_2_6::license::default_acquire(ivbm2_2_6::license::ui_mode_type const&, std::string const&) ()
#8  0x00007ffff6e4a7a5 in dicerengine2::internal::ResultImpl::isFinalized() const () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/libamplxe_dicerengine_core_2.24.so
#9  0x00007ffff6e9fad6 in dicerengine2::Result::isFinalized() const () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/libamplxe_dicerengine_core_2.24.so
#10 0x00007ffff6f1c817 in dicerengine2::Engine::isFinalized() const () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/libamplxe_dicerengine_core_2.24.so
#11 0x00007ffff72e9f96 in dicerengine2::internal::FinalizeCommand::execute(msngr2::IProgress*, gen_helpers2::variant_bag_t const&) ()
   from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/libamplxe_dicerengine_climgr_2.24.so
#12 0x00007ffff72de44b in dicerengine2::internal::CliCommander::execute(gen_helpers2::variant_bag_t const&, msngr2::IProgress*) ()
#13 0x00007ffff72cf7f3 in dicerengine2::CliManager::execute(gen_helpers2::variant_bag_t const&, msngr2::IProgress*) const ()
#14 0x000000000041a215 in ?? ()
#15 0x00000000004126f8 in ?? ()
#16 0x00007ffff14ceb15 in __libc_start_main () from /lib64/libc.so.6
#17 0x0000000000406c59 in ?? ()
#18 0x00007fffffffc988 in ?? ()
#19 0x000000000000001c in ?? ()
#20 0x0000000000000004 in ?? ()
#21 0x00007fffffffcdb7 in ?? ()
#22 0x00007fffffffcdf5 in ?? ()
#23 0x00007fffffffcdff in ?? ()
#24 0x00007fffffffce02 in ?? ()
#25 0x0000000000000000 in ?? ()
[New Thread 0x7fffe90d7700 (LWP 76950)]
[New Thread 0x7fffe175d700 (LWP 76961)]
[New Thread 0x7fffe0f5b700 (LWP 76963)]
[New Thread 0x7fffe135c700 (LWP 76962)]
[New Thread 0x7fffe0b5a700 (LWP 76964)]
[New Thread 0x7fffdbfff700 (LWP 76965)]
[New Thread 0x7fffe0759700 (LWP 76966)]
[New Thread 0x7fffdbbfe700 (LWP 76967)]
amplxe: Executing actions 39 % Resolving information for `libgcc_s.so.1'
amplxe: Executing actions 41 % Resolving information for `libstdc++.so.6'
amplxe: Executing actions 42 % Resolving information for `libpthread.so.0'
amplxe: Executing actions 42 % Resolving information for `libc-dynamic.so'
amplxe: Executing actions 43 % Resolving information for `ld-linux-x86-64.so.2'
[Thread 0x7fffdbbfe700 (LWP 76967) exited]
[Thread 0x7fffe0759700 (LWP 76966) exited]
[Thread 0x7fffe0b5a700 (LWP 76964) exited]
[Thread 0x7fffe0f5b700 (LWP 76963) exited]
[Thread 0x7fffe135c700 (LWP 76962) exited]
[Thread 0x7fffe175d700 (LWP 76961) exited]
[Thread 0x7fffdbfff700 (LWP 76965) exited]
(gdb) bt
#1  0x00007fffeff8f53d in Ox09f4c65d2b01757d () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#2  0x00007fffeff581fd in Ox09f4f9004ed09aff () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#3  0x00007fffeff55fe5 in ?? () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#4  0x00007fffeff56767 in Ox09f4e0f65c3c0661 () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#5  0x00007fffeff56a43 in Ox09f4e0d2387364fd () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#6  0x00007fffeff56c67 in Ox09f4e0d53200e445 () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#7  0x00007fffeff69e42 in Ox09f4e78c22d8ecba () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#8  0x00007fffeff52f0b in Ox09f4dec70f7db7b2 () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#9  0x00007fffeff52fb7 in lc_auth_data () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#10 0x00007fffeff3cdc9 in flex_config () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#11 0x00007fffeff3ffc2 in checkout_license(char const*, unsigned int, int, int, int, int, char const*) ()
#12 0x00007fffeff40ccb in flex_checkout_license () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so
#13 0x00007fffeff4338f in ivbm2_2_6::license::checkout_internal(std::vector<std::string, std::allocator<std::string> > const&) ()
#14 0x00007fffeff49c93 in ivbm2_2_6::license::acquire_internal(std::vector<std::string, std::allocator<std::string> > const&) ()
#15 0x00007fffeff4afe6 in ivbm2_2_6::license::default_acquire(ivbm2_2_6::license::ui_mode_type const&, std::string const&) ()
#16 0x00007ffff3902b29 in featurestat_1_3_3::license_info_provider_impl_t::license_info_provider_impl_t() ()
#17 0x00007ffff3938b84 in featurestat_1_3_3::statistic_t::get() () from /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/libamplxe_featurestat_core_1.3.so
#18 0x0000000000412704 in ?? ()
#19 0x00007ffff14ceb15 in __libc_start_main () from /lib64/libc.so.6
#20 0x0000000000406c59 in ?? ()
#21 0x00007fffffffc988 in ?? ()
#22 0x000000000000001c in ?? ()
#23 0x0000000000000004 in ?? ()
#24 0x00007fffffffcdb7 in ?? ()
#25 0x00007fffffffcdf5 in ?? ()
#26 0x00007fffffffcdff in ?? ()
#27 0x00007fffffffce02 in ?? ()
#28 0x0000000000000000 in ?? ()
[New Thread 0x7fffe90d7700 (LWP 77392)]
[New Thread 0x7fffe175d700 (LWP 77397)]
[New Thread 0x7fffe135c700 (LWP 77398)]
[New Thread 0x7fffe0f5b700 (LWP 77399)]
[New Thread 0x7fffe0759700 (LWP 77401)]
[New Thread 0x7fffdbfff700 (LWP 77402)]
[New Thread 0x7fffe0b5a700 (LWP 77400)]
[New Thread 0x7fffdbbfe700 (LWP 77403)]
amplxe: Executing actions 40 % Resolving information for `libc.so.6'
amplxe: Executing actions 40 % Resolving information for `WriteTest'
amplxe: Executing actions 40 % Resolving information for `pinbin'
amplxe: Executing actions 41 % Resolving information for `libc-dynamic.so'
[Thread 0x7fffe0759700 (LWP 77401) exited]
[Thread 0x7fffdbbfe700 (LWP 77403) exited]
[Thread 0x7fffe0b5a700 (LWP 77400) exited]
[Thread 0x7fffe0f5b700 (LWP 77399) exited]
[Thread 0x7fffdbfff700 (LWP 77402) exited]
[Thread 0x7fffe135c700 (LWP 77398) exited]
[Thread 0x7fffe175d700 (LWP 77397) exited]
*** Error in `/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/amplxe-cl': free(): invalid next size (normal): 0x00000000009ac100 ***
======= Backtrace: =========
/lib64/libc.so.6(+0x7d053)[0x7ffff152a053]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so(flex_kwd_is_end+0x24)[0x7fffeff3bc24]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so(+0x4802c)[0x7fffeff3c02c]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so(flex_kwd_search+0x1c)[0x7fffeff3ccbc]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so(_Z16checkout_licensePKcjiiiiS0_+0x1749)[0x7fffeff40029]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so(flex_checkout_license+0x5b)[0x7fffeff40ccb]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so(_ZN9ivbm2_2_67license17checkout_internalERKSt6vectorISsSaISsEE+0x7f)[0x7fffeff4338f]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so(_ZN9ivbm2_2_67license16acquire_internalERKSt6vectorISsSaISsEE+0x33)[0x7fffeff49c93]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/../lib64/libamplxe_ivbm_core_2.6.so(_ZN9ivbm2_2_67license15default_acquireERKNS0_12ui_mode_typeERKSs+0xd6)[0x7fffeff4afe6]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/libamplxe_featurestat_core_1.3.so(_ZN17featurestat_1_3_328license_info_provider_impl_tC1Ev+0x79)[0x7ffff3902b29]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/../lib64/libamplxe_featurestat_core_1.3.so(_ZN17featurestat_1_3_311statistic_t3getEv+0x1a4)[0x7ffff3938b84]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/amplxe-cl[0x412704]
/lib64/libc.so.6(__libc_start_main+0xf5)[0x7ffff14ceb15]
/opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/amplxe-cl[0x406c59]
======= Memory map: ========
00400000-00432000 r-xp 00000000 fd:02 13897416                           /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/amplxe-cl
00632000-00633000 rw-p 00032000 fd:02 13897416                           /opt/intel/vtune_amplifier_xe_2017.0.2.478468/bin64/amplxe-cl
00633000-0ba8b000 rw-p 00000000 00:00 0                                  [heap]
7fffbc000000-7fffbc9cd000 rw-p 00000000 00:00 0
7fffbc9cd000-7fffc0000000 ---p 00000000 00:00 0
7fffc4000000-7fffc63ea000 rw-p 00000000 00:00 0
7fffc63ea000-7fffc8000000 ---p 00000000 00:00 0
7fffc8000000-7fffc8cec000 rw-p 00000000 00:00 0
7fffc8cec000-7fffcc000000 ---p 00000000 00:00 0
7fffcc000000-7fffccb09000 rw-p 00000000 00:00 0
7fffccb09000-7fffd0000000 ---p 00000000 00:00 0
7fffd0000000-7fffd0e8c000 rw-p 00000000 00:00 0
7fffd0e8c000-7fffd4000000 ---p 00000000 00:00 0
7fffd4000000-7fffd53a0000 rw-p 00000000 00:00 0
7fffd53a0000-7fffd8000000 ---p 00000000 00:00 0
7fffda69b000-7fffda89b000 rw-p 00000000 00:00 0
7fffdadde000-7fffdafec000 r-xp 00000000 fd:02 13897771                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_plugin_knc_1.11.so
7fffdafec000-7fffdb1eb000 ---p 0020e000 fd:02 13897771                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_plugin_knc_1.11.so
7fffdb1eb000-7fffdb237000 rw-p 0020d000 fd:02 13897771                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_plugin_knc_1.11.so
7fffdb237000-7fffdb23b000 rw-p 00000000 00:00 0
7fffdb23b000-7fffdb586000 r-xp 00000000 fd:02 13897770                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_plugin_default_1.11.so
7fffdb586000-7fffdb785000 ---p 0034b000 fd:02 13897770                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_plugin_default_1.11.so
7fffdb785000-7fffdb7fa000 rw-p 0034a000 fd:02 13897770                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_plugin_default_1.11.so
7fffdb7fa000-7fffdb7fe000 rw-p 00000000 00:00 0
7fffdb7fe000-7fffdb7ff000 ---p 00000000 00:00 0
7fffdb7ff000-7fffdbbff000 rwxp 00000000 00:00 0
7fffdbbff000-7fffdbc00000 ---p 00000000 00:00 0
7fffdbc00000-7fffdc000000 rwxp 00000000 00:00 0
7fffdc000000-7fffdda18000 rw-p 00000000 00:00 0
7fffdda18000-7fffe0000000 ---p 00000000 00:00 0
7fffe0041000-7fffe0141000 rw-p 00000000 00:00 0
7fffe0141000-7fffe0157000 r-xp 00000000 fd:02 13897739                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_libipt_1.2.so
7fffe0157000-7fffe0357000 ---p 00016000 fd:02 13897739                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_libipt_1.2.so
7fffe0357000-7fffe0359000 rw-p 00016000 fd:02 13897739                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_libipt_1.2.so
7fffe0359000-7fffe035a000 ---p 00000000 00:00 0
7fffe035a000-7fffe075a000 rwxp 00000000 00:00 0
7fffe075a000-7fffe075b000 ---p 00000000 00:00 0
7fffe075b000-7fffe0b5b000 rwxp 00000000 00:00 0
7fffe0b5b000-7fffe0b5c000 ---p 00000000 00:00 0
7fffe0b5c000-7fffe0f5c000 rwxp 00000000 00:00 0
7fffe0f5c000-7fffe0f5d000 ---p 00000000 00:00 0
7fffe0f5d000-7fffe135d000 rwxp 00000000 00:00 0
7fffe135d000-7fffe135e000 ---p 00000000 00:00 0
7fffe135e000-7fffe175e000 rwxp 00000000 00:00 0
7fffe1794000-7fffe17ae000 r-xp 00000000 fd:02 13897769                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_image_1.11.so
7fffe17ae000-7fffe19ae000 ---p 0001a000 fd:02 13897769                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_image_1.11.so
7fffe19ae000-7fffe19b0000 rw-p 0001a000 fd:02 13897769                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_image_1.11.so
7fffe19b0000-7fffe1bb0000 rw-p 00000000 00:00 0
7fffe1bb0000-7fffe80d7000 r--p 00000000 fd:02 22156817                   /usr/lib/locale/locale-archive
7fffe80d7000-7fffe80d8000 ---p 00000000 00:00 0
7fffe80d8000-7fffe90d8000 rwxp 00000000 00:00 0                          [stack:77392]
7fffe90d8000-7fffe90e4000 r-xp 00000000 fd:02 21889623                   /usr/lib64/libnss_files-2.17.so
7fffe90e4000-7fffe92e3000 ---p 0000c000 fd:02 21889623                   /usr/lib64/libnss_files-2.17.so
7fffe92e3000-7fffe92e4000 r--p 0000b000 fd:02 21889623                   /usr/lib64/libnss_files-2.17.so
7fffe92e4000-7fffe92e5000 rw-p 0000c000 fd:02 21889623                   /usr/lib64/libnss_files-2.17.so
7fffe92e5000-7fffe92eb000 rw-p 00000000 00:00 0
7fffe92eb000-7fffe9608000 r-xp 00000000 fd:02 13897774                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_timelinedataprovider_core_1.22.so
7fffe9608000-7fffe9807000 ---p 0031d000 fd:02 13897774                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_timelinedataprovider_core_1.22.so
7fffe9807000-7fffe9819000 rw-p 0031c000 fd:02 13897774                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_timelinedataprovider_core_1.22.so
7fffe9819000-7fffe981a000 rw-p 00000000 00:00 0
7fffe981a000-7fffe9832000 r-xp 00000000 fd:02 13897761                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_sampling_utils_2.0.so
7fffe9832000-7fffe9a31000 ---p 00018000 fd:02 13897761                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_sampling_utils_2.0.so
7fffe9a31000-7fffe9a32000 r--p 00017000 fd:02 13897761                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_sampling_utils_2.0.so
7fffe9a32000-7fffe9a33000 rw-p 00018000 fd:02 13897761                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_sampling_utils_2.0.so
7fffe9a33000-7fffe9a34000 rw-p 00000000 00:00 0
7fffe9a34000-7fffe9aab000 r-xp 00000000 fd:02 13897772                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_tbrw_2.0.so
7fffe9aab000-7fffe9caa000 ---p 00077000 fd:02 13897772                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_tbrw_2.0.so
7fffe9caa000-7fffe9cac000 r--p 00076000 fd:02 13897772                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_tbrw_2.0.so
7fffe9cac000-7fffe9cad000 rw-p 00078000 fd:02 13897772                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_tbrw_2.0.so
7fffe9cad000-7fffe9cb2000 r-xp 00000000 fd:02 13897773                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_tbrw_smrk_2.0.so
7fffe9cb2000-7fffe9eb1000 ---p 00005000 fd:02 13897773                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_tbrw_smrk_2.0.so
7fffe9eb1000-7fffe9eb2000 rw-p 00004000 fd:02 13897773                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_tbrw_smrk_2.0.so
7fffe9eb2000-7fffe9ed2000 r-xp 00000000 fd:02 13897881                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libplatform_picker.so
7fffe9ed2000-7fffea0d2000 ---p 00020000 fd:02 13897881                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libplatform_picker.so
7fffea0d2000-7fffea0d3000 r--p 00020000 fd:02 13897881                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libplatform_picker.so
7fffea0d3000-7fffea0d6000 rw-p 00021000 fd:02 13897881                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libplatform_picker.so
7fffea0d6000-7fffea0fa000 r-xp 00000000 fd:02 13897708                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_iostreams_1.55.so
7fffea0fa000-7fffea2f9000 ---p 00024000 fd:02 13897708                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_iostreams_1.55.so
7fffea2f9000-7fffea2fb000 rw-p 00023000 fd:02 13897708                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_iostreams_1.55.so
7fffea2fb000-7fffea371000 r-xp 00000000 fd:02 13897762                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_smip_core_3.24.so
7fffea371000-7fffea570000 ---p 00076000 fd:02 13897762                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_smip_core_3.24.so
7fffea570000-7fffea577000 rw-p 00075000 fd:02 13897762                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_smip_core_3.24.so
7fffea577000-7fffea5ab000 r-xp 00000000 fd:02 13897738                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_ism_demangler_3.34.so
7fffea5ab000-7fffea7aa000 ---p 00034000 fd:02 13897738                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_ism_demangler_3.34.so
7fffea7aa000-7fffea7ac000 rw-p 00033000 fd:02 13897738                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_ism_demangler_3.34.so
7fffea7ac000-7fffea8eb000 r-xp 00000000 fd:02 13897737                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_ism_core_3.34.so
7fffea8eb000-7fffeaaeb000 ---p 0013f000 fd:02 13897737                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_ism_core_3.34.so
7fffeaaeb000-7fffeaaf6000 rw-p 0013f000 fd:02 13897737                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_ism_core_3.34.so
7fffeaaf6000-7fffeab0a000 r-xp 00000000 fd:02 13897764                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_smip_ismwrapper_3.24.so
7fffeab0a000-7fffead0a000 ---p 00014000 fd:02 13897764                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_smip_ismwrapper_3.24.so
7fffead0a000-7fffead0c000 rw-p 00014000 fd:02 13897764                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_smip_ismwrapper_3.24.so
7fffead0c000-7fffead1a000 r-xp 00000000 fd:02 13897766                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_smip_mrtewrapper_3.24.so
7fffead1a000-7fffeaf1a000 ---p 0000e000 fd:02 13897766                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_smip_mrtewrapper_3.24.so
7fffeaf1a000-7fffeaf1b000 rw-p 0000e000 fd:02 13897766                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_smip_mrtewrapper_3.24.so
7fffeaf1b000-7fffeaf8a000 r-xp 00000000 fd:02 13897741                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_libxslt_1.1.so
7fffeaf8a000-7fffeb18a000 ---p 0006f000 fd:02 13897741                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_libxslt_1.1.so
7fffeb18a000-7fffeb18c000 rw-p 0006f000 fd:02 13897741                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_libxslt_1.1.so
7fffeb18c000-7fffeb18e000 r-xp 00000000 fd:02 21889639                   /usr/lib64/libutil-2.17.so
7fffeb18e000-7fffeb38d000 ---p 00002000 fd:02 21889639                   /usr/lib64/libutil-2.17.so
7fffeb38d000-7fffeb38e000 r--p 00001000 fd:02 21889639                   /usr/lib64/libutil-2.17.so
7fffeb38e000-7fffeb38f000 rw-p 00002000 fd:02 21889639                   /usr/lib64/libutil-2.17.so
7fffeb38f000-7fffeb396000 r-xp 00000000 fd:02 21889635                   /usr/lib64/librt-2.17.so
7fffeb396000-7fffeb595000 ---p 00007000 fd:02 21889635                   /usr/lib64/librt-2.17.so
7fffeb595000-7fffeb596000 r--p 00006000 fd:02 21889635                   /usr/lib64/librt-2.17.so
7fffeb596000-7fffeb597000 rw-p 00007000 fd:02 21889635                   /usr/lib64/librt-2.17.so
7fffeb597000-7fffec090000 r-xp 00000000 fd:02 13897719                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dbinterface_sqlite_1.129.so
7fffec090000-7fffec290000 ---p 00af9000 fd:02 13897719                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dbinterface_sqlite_1.129.so
7fffec290000-7fffec2b7000 rw-p 00af9000 fd:02 13897719                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dbinterface_sqlite_1.129.so
7fffec2b7000-7fffec2ca000 rw-p 00000000 00:00 0
7fffec2ca000-7fffec875000 r-xp 00000000 fd:02 13897728                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dpihelpers_1.33.so
7fffec875000-7fffeca74000 ---p 005ab000 fd:02 13897728                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dpihelpers_1.33.so
7fffeca74000-7fffecab0000 rw-p 005aa000 fd:02 13897728                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dpihelpers_1.33.so
7fffecab0000-7fffecab3000 rw-p 00000000 00:00 0
7fffecab3000-7fffecd01000 r-xp 00000000 fd:02 13897725                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerhelpers_core_1.21.so
7fffecd01000-7fffecf00000 ---p 0024e000 fd:02 13897725                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerhelpers_core_1.21.so
7fffecf00000-7fffecf0b000 rw-p 0024d000 fd:02 13897725                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerhelpers_core_1.21.so
7fffecf0b000-7fffecf0d000 rw-p 00000000 00:00 0
7fffecf0d000-7fffecfac000 r-xp 00000000 fd:02 13897720                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dbiproviders_1.5.so
7fffecfac000-7fffed1ac000 ---p 0009f000 fd:02 13897720                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dbiproviders_1.5.so
7fffed1ac000-7fffed1b1000 rw-p 0009f000 fd:02 13897720                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dbiproviders_1.5.so
7fffed1b1000-7fffed1c9000 r-xp 00000000 fd:02 13897775                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_viewpointhelpers_core_1.0.so
7fffed1c9000-7fffed3c9000 ---p 00018000 fd:02 13897775                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_viewpointhelpers_core_1.0.so
7fffed3c9000-7fffed3cb000 rw-p 00018000 fd:02 13897775                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_viewpointhelpers_core_1.0.so
7fffed3cb000-7fffed6ff000 r-xp 00000000 fd:02 13897743                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_mrtesym_jitreader_3.9.so
7fffed6ff000-7fffed8ff000 ---p 00334000 fd:02 13897743                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_mrtesym_jitreader_3.9.so
7fffed8ff000-7fffed969000 rw-p 00334000 fd:02 13897743                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_mrtesym_jitreader_3.9.so
7fffed969000-7fffed96e000 rw-p 00000000 00:00 0
7fffed96e000-7fffed97a000 r-xp 00000000 fd:02 13897731                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_file_finder_binary_validators_2.19.so
7fffed97a000-7fffedb7a000 ---p 0000c000 fd:02 13897731                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_file_finder_binary_validators_2.19.so
7fffedb7a000-7fffedb7c000 rw-p 0000c000 fd:02 13897731                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_file_finder_binary_validators_2.19.so
7fffedb7c000-7fffee14f000 r-xp 00000000 fd:02 13897746                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_perftracerw_api_1.29.so
7fffee14f000-7fffee34e000 ---p 005d3000 fd:02 13897746                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_perftracerw_api_1.29.so
7fffee34e000-7fffee3e2000 rw-p 005d2000 fd:02 13897746                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_perftracerw_api_1.29.so
7fffee3e2000-7fffee3e7000 rw-p 00000000 00:00 0
7fffee3e7000-7fffee464000 r-xp 00000000 fd:02 13897748                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_pytraceplug_1.2.so
7fffee464000-7fffee663000 ---p 0007d000 fd:02 13897748                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_pytraceplug_1.2.so
7fffee663000-7fffee665000 rw-p 0007c000 fd:02 13897748                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_pytraceplug_1.2.so
7fffee665000-7fffee666000 rw-p 00000000 00:00 0
7fffee666000-7fffee7ec000 r-xp 00000000 fd:02 13897721                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicer2_plugin_sep_3.7.so
7fffee7ec000-7fffee9ec000 ---p 00186000 fd:02 13897721                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicer2_plugin_sep_3.7.so
7fffee9ec000-7fffee9f0000 rw-p 00186000 fd:02 13897721                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicer2_plugin_sep_3.7.so
7fffee9f0000-7fffee9f2000 rw-p 00000000 00:00 0
7fffee9f2000-7fffeea10000 r-xp 00000000 fd:02 13897742                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_loadermodel_1.1.so
7fffeea10000-7fffeec0f000 ---p 0001e000 fd:02 13897742                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_loadermodel_1.1.so
7fffeec0f000-7fffeec11000 rw-p 0001d000 fd:02 13897742                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_loadermodel_1.1.so
7fffeec11000-7fffefc77000 r-xp 00000000 fd:02 13897722                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicer2_plugin_tpss_2.20.so
7fffefc77000-7fffefe76000 ---p 01066000 fd:02 13897722                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicer2_plugin_tpss_2.20.so
7fffefe76000-7fffefed4000 rw-p 01065000 fd:02 13897722                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicer2_plugin_tpss_2.20.so
7fffefed4000-7fffefef4000 rw-p 00000000 00:00 0
7fffefef4000-7ffff0060000 r-xp 00000000 fd:02 13900621                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_ivbm_core_2.6.so
7ffff0060000-7ffff0260000 ---p 0016c000 fd:02 13900621                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_ivbm_core_2.6.so
7ffff0260000-7ffff0270000 rw-p 0016c000 fd:02 13900621                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_ivbm_core_2.6.so
7ffff0270000-7ffff0277000 rw-p 00000000 00:00 0
7ffff0277000-7ffff0281000 r-xp 00000000 fd:02 13897758                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_reporter_dicer_2.8.so
7ffff0281000-7ffff0481000 ---p 0000a000 fd:02 13897758                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_reporter_dicer_2.8.so
7ffff0481000-7ffff0482000 rw-p 0000a000 fd:02 13897758                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_reporter_dicer_2.8.so
7ffff0482000-7ffff05db000 r-xp 00000000 fd:02 13897718                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dbinterface_core_1.129.so
7ffff05db000-7ffff07db000 ---p 00159000 fd:02 13897718                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dbinterface_core_1.129.so
7ffff07db000-7ffff07e5000 rw-p 00159000 fd:02 13897718                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dbinterface_core_1.129.so
7ffff07e5000-7ffff0960000 r-xp 00000000 fd:02 13897726                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerresolver_core_2.8.so
7ffff0960000-7ffff0b60000 ---p 0017b000 fd:02 13897726                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerresolver_core_2.8.so
7ffff0b60000-7ffff0b6f000 rw-p 0017b000 fd:02 13897726                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerresolver_core_2.8.so
7ffff0b6f000-7ffff0b70000 rw-p 00000000 00:00 0
7ffff0b70000-7ffff0c79000 r-xp 00000000 fd:02 13897727                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerresolver_impl_2.8.so
7ffff0c79000-7ffff0e79000 ---p 00109000 fd:02 13897727                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerresolver_impl_2.8.so
7ffff0e79000-7ffff0e7e000 rw-p 00109000 fd:02 13897727                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerresolver_impl_2.8.so
7ffff0e7e000-7ffff0e7f000 rw-p 00000000 00:00 0
7ffff0e7f000-7ffff0e91000 r-xp 00000000 fd:02 13897732                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_file_finder_climgr_2.19.so
7ffff0e91000-7ffff1090000 ---p 00012000 fd:02 13897732                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_file_finder_climgr_2.19.so
7ffff1090000-7ffff1092000 rw-p 00011000 fd:02 13897732                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_file_finder_climgr_2.19.so
7ffff1092000-7ffff10a8000 r-xp 00000000 fd:02 13897745                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_msngr_reader_2.8.so
7ffff10a8000-7ffff12a8000 ---p 00016000 fd:02 13897745                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_msngr_reader_2.8.so
7ffff12a8000-7ffff12a9000 rw-p 00016000 fd:02 13897745                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_msngr_reader_2.8.so
7ffff12a9000-7ffff12ac000 r-xp 00000000 fd:02 21889611                   /usr/lib64/libdl-2.17.so
7ffff12ac000-7ffff14ab000 ---p 00003000 fd:02 21889611                   /usr/lib64/libdl-2.17.so
7ffff14ab000-7ffff14ac000 r--p 00002000 fd:02 21889611                   /usr/lib64/libdl-2.17.so
7ffff14ac000-7ffff14ad000 rw-p 00003000 fd:02 21889611                   /usr/lib64/libdl-2.17.so
7ffff14ad000-7ffff1664000 r-xp 00000000 fd:02 21889605                   /usr/lib64/libc-2.17.so
7ffff1664000-7ffff1864000 ---p 001b7000 fd:02 21889605                   /usr/lib64/libc-2.17.so
7ffff1864000-7ffff1868000 r--p 001b7000 fd:02 21889605                   /usr/lib64/libc-2.17.so
7ffff1868000-7ffff186a000 rw-p 001bb000 fd:02 21889605                   /usr/lib64/libc-2.17.so
7ffff186a000-7ffff186f000 rw-p 00000000 00:00 0
7ffff186f000-7ffff1885000 r-xp 00000000 fd:02 13897823                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libgcc_s.so.1
7ffff1885000-7ffff1a85000 ---p 00016000 fd:02 13897823                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libgcc_s.so.1
7ffff1a85000-7ffff1a86000 rw-p 00016000 fd:02 13897823                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libgcc_s.so.1
7ffff1a86000-7ffff1b86000 r-xp 00000000 fd:02 13897901                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libstdc++.so.6.0.20
7ffff1b86000-7ffff1d85000 ---p 00100000 fd:02 13897901                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libstdc++.so.6.0.20
7ffff1d85000-7ffff1d8e000 r--p 000ff000 fd:02 13897901                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libstdc++.so.6.0.20
7ffff1d8e000-7ffff1d90000 rw-p 00108000 fd:02 13897901                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libstdc++.so.6.0.20
7ffff1d90000-7ffff1da5000 rw-p 00000000 00:00 0
7ffff1da5000-7ffff1ea6000 r-xp 00000000 fd:02 21889613                   /usr/lib64/libm-2.17.so
7ffff1ea6000-7ffff20a5000 ---p 00101000 fd:02 21889613                   /usr/lib64/libm-2.17.so
7ffff20a5000-7ffff20a6000 r--p 00100000 fd:02 21889613                   /usr/lib64/libm-2.17.so
7ffff20a6000-7ffff20a7000 rw-p 00101000 fd:02 21889613                   /usr/lib64/libm-2.17.so
7ffff20a7000-7ffff21b3000 r-xp 00000000 fd:02 13897717                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cpil_2.18.so
7ffff21b3000-7ffff23b2000 ---p 0010c000 fd:02 13897717                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cpil_2.18.so
7ffff23b2000-7ffff23ba000 rw-p 0010b000 fd:02 13897717                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cpil_2.18.so
7ffff23ba000-7ffff23d0000 r-xp 00000000 fd:02 21889631                   /usr/lib64/libpthread-2.17.so
7ffff23d0000-7ffff25d0000 ---p 00016000 fd:02 21889631                   /usr/lib64/libpthread-2.17.so
7ffff25d0000-7ffff25d1000 r--p 00016000 fd:02 21889631                   /usr/lib64/libpthread-2.17.so
7ffff25d1000-7ffff25d2000 rw-p 00017000 fd:02 21889631                   /usr/lib64/libpthread-2.17.so
7ffff25d2000-7ffff25d6000 rw-p 00000000 00:00 0
7ffff25d6000-7ffff2659000 r-xp 00000000 fd:02 13897750                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagent_log_1.11.so
7ffff2659000-7ffff2858000 ---p 00083000 fd:02 13897750                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagent_log_1.11.so
7ffff2858000-7ffff285f000 rw-p 00082000 fd:02 13897750                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagent_log_1.11.so
7ffff285f000-7ffff2862000 r-xp 00000000 fd:02 13897711                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_system_1.55.so
7ffff2862000-7ffff2a62000 ---p 00003000 fd:02 13897711                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_system_1.55.so
7ffff2a62000-7ffff2a63000 rw-p 00003000 fd:02 13897711                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_system_1.55.so
7ffff2a63000-7ffff2a74000 r-xp 00000000 fd:02 13897706                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_date_time_1.55.so
7ffff2a74000-7ffff2c74000 ---p 00011000 fd:02 13897706                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_date_time_1.55.so
7ffff2c74000-7ffff2c76000 rw-p 00011000 fd:02 13897706                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_date_time_1.55.so
7ffff2c76000-7ffff2c96000 r-xp 00000000 fd:02 13897712                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_thread_1.55.so
7ffff2c96000-7ffff2e95000 ---p 00020000 fd:02 13897712                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_thread_1.55.so
7ffff2e95000-7ffff2e97000 rw-p 0001f000 fd:02 13897712                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_thread_1.55.so
7ffff2e97000-7ffff3138000 r-xp 00000000 fd:02 13897735                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_gen_helpers_core_2.32.so
7ffff3138000-7ffff3338000 ---p 002a1000 fd:02 13897735                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_gen_helpers_core_2.32.so
7ffff3338000-7ffff3356000 rw-p 002a1000 fd:02 13897735                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_gen_helpers_core_2.32.so
7ffff3356000-7ffff38ed000 rw-p 00000000 00:00 0
7ffff38ed000-7ffff3955000 r-xp 00000000 fd:02 13897730                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_featurestat_core_1.3.so
7ffff3955000-7ffff3b55000 ---p 00068000 fd:02 13897730                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_featurestat_core_1.3.so
7ffff3b55000-7ffff3b58000 rw-p 00068000 fd:02 13897730                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_featurestat_core_1.3.so
7ffff3b58000-7ffff3b59000 rw-p 00000000 00:00 0
7ffff3b59000-7ffff3b80000 r-xp 00000000 fd:02 13897707                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_filesystem_1.55.so
7ffff3b80000-7ffff3d7f000 ---p 00027000 fd:02 13897707                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_filesystem_1.55.so
7ffff3d7f000-7ffff3d81000 rw-p 00026000 fd:02 13897707                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_filesystem_1.55.so
7ffff3d81000-7ffff3da1000 r-xp 00000000 fd:02 13897749                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagent_assert_1.18.so
7ffff3da1000-7ffff3fa0000 ---p 00020000 fd:02 13897749                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagent_assert_1.18.so
7ffff3fa0000-7ffff3fa2000 rw-p 0001f000 fd:02 13897749                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagent_assert_1.18.so
7ffff3fa2000-7ffff3fc2000 r-xp 00000000 fd:02 13897768                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_factory_1.11.so
7ffff3fc2000-7ffff41c2000 ---p 00020000 fd:02 13897768                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_factory_1.11.so
7ffff41c2000-7ffff41c4000 rw-p 00020000 fd:02 13897768                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_stackwalk_factory_1.11.so
7ffff41c4000-7ffff41d9000 r-xp 00000000 fd:02 13897753                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagentminidump_bthelp_1.18.so
7ffff41d9000-7ffff43d9000 ---p 00015000 fd:02 13897753                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagentminidump_bthelp_1.18.so
7ffff43d9000-7ffff43db000 rw-p 00015000 fd:02 13897753                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagentminidump_bthelp_1.18.so
7ffff43db000-7ffff4558000 r-xp 00000000 fd:02 13897715                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cfgmgr_2.26.so
7ffff4558000-7ffff4757000 ---p 0017d000 fd:02 13897715                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cfgmgr_2.26.so
7ffff4757000-7ffff476c000 rw-p 0017c000 fd:02 13897715                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cfgmgr_2.26.so
7ffff476c000-7ffff490b000 r-xp 00000000 fd:02 13897710                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_regex_1.55.so
7ffff490b000-7ffff4b0a000 ---p 0019f000 fd:02 13897710                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_regex_1.55.so
7ffff4b0a000-7ffff4b13000 rw-p 0019e000 fd:02 13897710                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_regex_1.55.so
7ffff4b13000-7ffff4b27000 r-xp 00000000 fd:02 13897751                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagent_qfagent_1.11.so
7ffff4b27000-7ffff4d26000 ---p 00014000 fd:02 13897751                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagent_qfagent_1.11.so
7ffff4d26000-7ffff4d27000 rw-p 00013000 fd:02 13897751                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagent_qfagent_1.11.so
7ffff4d27000-7ffff4dfc000 r-xp 00000000 fd:02 13897754                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagentminidump_core_1.18.so
7ffff4dfc000-7ffff4ffb000 ---p 000d5000 fd:02 13897754                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagentminidump_core_1.18.so
7ffff4ffb000-7ffff5000000 rw-p 000d4000 fd:02 13897754                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_qfagentminidump_core_1.18.so
7ffff5000000-7ffff5001000 rw-p 00000000 00:00 0
7ffff5001000-7ffff5055000 r-xp 00000000 fd:02 13897716                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_clpt_3.7.so
7ffff5055000-7ffff5255000 ---p 00054000 fd:02 13897716                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_clpt_3.7.so
7ffff5255000-7ffff5257000 rw-p 00054000 fd:02 13897716                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_clpt_3.7.so
7ffff5257000-7ffff5483000 r-xp 00000000 fd:02 13897740                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_libxml_2.7.so
7ffff5483000-7ffff5683000 ---p 0022c000 fd:02 13897740                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_libxml_2.7.so
7ffff5683000-7ffff568f000 rw-p 0022c000 fd:02 13897740                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_libxml_2.7.so
7ffff568f000-7ffff5690000 rw-p 00000000 00:00 0
7ffff5690000-7ffff56b3000 r-xp 00000000 fd:02 13897744                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_msngr_cmd_2.8.so
7ffff56b3000-7ffff58b2000 ---p 00023000 fd:02 13897744                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_msngr_cmd_2.8.so
7ffff58b2000-7ffff58b5000 rw-p 00022000 fd:02 13897744                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_msngr_cmd_2.8.so
7ffff58b5000-7ffff5c0d000 r-xp 00000000 fd:02 13897747                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_python_core_2.5.so
7ffff5c0d000-7ffff5e0d000 ---p 00358000 fd:02 13897747                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_python_core_2.5.so
7ffff5e0d000-7ffff5e87000 rw-p 00358000 fd:02 13897747                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_python_core_2.5.so
7ffff5e87000-7ffff5e90000 rw-p 00000000 00:00 0
7ffff5e90000-7ffff5ee4000 r-xp 00000000 fd:02 13897709                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_python_shared_1.55.so
7ffff5ee4000-7ffff60e4000 ---p 00054000 fd:02 13897709                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_python_shared_1.55.so
7ffff60e4000-7ffff60e8000 rw-p 00054000 fd:02 13897709                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_boost_python_shared_1.55.so
7ffff60e8000-7ffff6101000 r-xp 00000000 fd:02 13897757                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_reporter_core_2.8.so
7ffff6101000-7ffff6300000 ---p 00019000 fd:02 13897757                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_reporter_core_2.8.so
7ffff6300000-7ffff6302000 rw-p 00018000 fd:02 13897757                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_reporter_core_2.8.so
7ffff6302000-7ffff630e000 r-xp 00000000 fd:02 13897756                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_reporter_climgr_2.8.so
7ffff630e000-7ffff650e000 ---p 0000c000 fd:02 13897756                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_reporter_climgr_2.8.so
7ffff650e000-7ffff650f000 rw-p 0000c000 fd:02 13897756                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_reporter_climgr_2.8.so
7ffff650f000-7ffff65b8000 r-xp 00000000 fd:02 13897733                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_file_finder_core_2.19.so
7ffff65b8000-7ffff67b8000 ---p 000a9000 fd:02 13897733                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_file_finder_core_2.19.so
7ffff67b8000-7ffff67c2000 rw-p 000a9000 fd:02 13897733                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_file_finder_core_2.19.so
7ffff67c2000-7ffff67f0000 r-xp 00000000 fd:02 13897906                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libtbbmalloc.so.2
7ffff67f0000-7ffff69f0000 ---p 0002e000 fd:02 13897906                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libtbbmalloc.so.2
7ffff69f0000-7ffff69f4000 rw-p 0002e000 fd:02 13897906                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libtbbmalloc.so.2
7ffff69f4000-7ffff6a16000 rw-p 00000000 00:00 0
7ffff6a16000-7ffff6a5e000 r-xp 00000000 fd:02 13897904                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libtbb.so.2
7ffff6a5e000-7ffff6c5e000 ---p 00048000 fd:02 13897904                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libtbb.so.2
7ffff6c5e000-7ffff6c63000 rw-p 00048000 fd:02 13897904                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libtbb.so.2
7ffff6c63000-7ffff6c65000 rw-p 00000000 00:00 0
7ffff6c65000-7ffff706f000 r-xp 00000000 fd:02 13897724                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerengine_core_2.24.so
7ffff706f000-7ffff726e000 ---p 0040a000 fd:02 13897724                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerengine_core_2.24.so
7ffff726e000-7ffff7291000 rw-p 00409000 fd:02 13897724                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerengine_core_2.24.so
7ffff7291000-7ffff7294000 rw-p 00000000 00:00 0
7ffff7294000-7ffff7311000 r-xp 00000000 fd:02 13897723                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerengine_climgr_2.24.so
7ffff7311000-7ffff7510000 ---p 0007d000 fd:02 13897723                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerengine_climgr_2.24.so
7ffff7510000-7ffff7516000 rw-p 0007c000 fd:02 13897723                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_dicerengine_climgr_2.24.so
7ffff7516000-7ffff75a6000 r-xp 00000000 fd:02 13897755                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_rdmgr_2.30.so
7ffff75a6000-7ffff77a6000 ---p 00090000 fd:02 13897755                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_rdmgr_2.30.so
7ffff77a6000-7ffff77b2000 rw-p 00090000 fd:02 13897755                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_rdmgr_2.30.so
7ffff77b2000-7ffff795e000 r-xp 00000000 fd:02 13897714                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cctrl_core_2.41.so
7ffff795e000-7ffff7b5e000 ---p 001ac000 fd:02 13897714                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cctrl_core_2.41.so
7ffff7b5e000-7ffff7b6e000 rw-p 001ac000 fd:02 13897714                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cctrl_core_2.41.so
7ffff7b6e000-7ffff7b6f000 rw-p 00000000 00:00 0
7ffff7b6f000-7ffff7bd7000 r-xp 00000000 fd:02 13897713                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cctrl_climgr_2.41.so
7ffff7bd7000-7ffff7dd6000 ---p 00068000 fd:02 13897713                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cctrl_climgr_2.41.so
7ffff7dd6000-7ffff7ddb000 rw-p 00067000 fd:02 13897713                   /opt/intel/vtune_amplifier_xe_2017.0.2.478468/lib64/libamplxe_cctrl_climgr_2.41.so
7ffff7ddb000-7ffff7dfc000 r-xp 00000000 fd:02 21891786                   /usr/lib64/ld-2.17.so
7ffff7e23000-7ffff7fde000 rw-p 00000000 00:00 0
7ffff7fe6000-7ffff7fe7000 rw-p 00000000 00:00 0
7ffff7fe7000-7ffff7fee000 r--s 00000000 fd:02 22155197                   /usr/lib64/gconv/gconv-modules.cache
7ffff7fee000-7ffff7ffa000 rw-p 00000000 00:00 0
7ffff7ffa000-7ffff7ffc000 r-xp 00000000 00:00 0                          [vdso]
7ffff7ffc000-7ffff7ffd000 r--p 00021000 fd:02 21891786                   /usr/lib64/ld-2.17.so
7ffff7ffd000-7ffff7ffe000 rw-p 00022000 fd:02 21891786                   /usr/lib64/ld-2.17.so
7ffff7ffe000-7ffff7fff000 rw-p 00000000 00:00 0
7ffffffdb000-7fffffffd000 rwxp 00000000 00:00 0                          [stack]
7fffffffd000-7ffffffff000 rw-p 00000000 00:00 0
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
Program received signal SIGABRT, Aborted.
0x00007ffff14e25f7 in raise () from /lib64/libc.so.6
I attached a crash_info.txt that one of the failed finalize attempts produced.
This isn't a major issue since I can just delete ~/.flexlmborrow but it does seem like something isn't right.
Ekaterina_L_Intel
Hello Jason,
Thanks a lot for reporting it and the amazing debug!
We will pass down the issue to our license team.
Regards, Katya
