Analyzers
5272 Discussions
Level 2 data cache event counters?
T_C
Below is a list of all the event counter I have available on my Ivy Bridge CPU. It contains "L1D" cache event counters, but there are no "L2D" counters- only "L2". I was under the impression the L2 cache is split in to data and instruction caches.
(I have read the descriptions of the below event counters and the "L1D" says "L1 data cache" and the "L2" says "L2 cache", implying it is not specific to the data cache).
What event counters should I use to measure data cache misses for L1/L2/L3, ignoring instruction cache misses?
ARITH.FPU_DIV_ACTIVE
BACLEARS.ANY
BR_MISP_RETIRED.ALL_BRANCHES_PS
CPU_CLK_UNHALTED.REF_TSC
CPU_CLK_UNHALTED.THREAD
CYCLE_ACTIVITY.CYCLES_NO_EXECUTE
CYCLE_ACTIVITY.STALLS_L1D_PENDING
CYCLE_ACTIVITY.STALLS_L2_PENDING
CYCLE_ACTIVITY.STALLS_LDM_PENDING
DSB2MITE_SWITCHES.PENALTY_CYCLES
DTLB_LOAD_MISSES.STLB_HIT
DTLB_LOAD_MISSES.WALK_DURATION
DTLB_STORE_MISSES.STLB_HIT
DTLB_STORE_MISSES.WALK_DURATION
ICACHE.IFETCH_STALL
ICACHE.MISSES
IDQ.ALL_DSB_CYCLES_4_UOPS
IDQ.ALL_DSB_CYCLES_ANY_UOPS
IDQ.ALL_MITE_CYCLES_4_UOPS
IDQ.ALL_MITE_CYCLES_ANY_UOPS
IDQ.MS_CYCLES
IDQ.MS_UOPS
IDQ_UOPS_NOT_DELIVERED.CORE
IDQ_UOPS_NOT_DELIVERED.CYCLES_0_UOPS_DELIV.CORE
ILD_STALL.LCP
INST_RETIRED.ANY
INST_RETIRED.PREC_DIST
INT_MISC.RECOVERY_CYCLES
ITLB_MISSES.WALK_DURATION
L1D.REPLACEMENT
L1D_PEND_MISS.PENDING
L2_LINES_IN.ALL
LD_BLOCKS.NO_SR
LD_BLOCKS.STORE_FORWARD
LD_BLOCKS_PARTIAL.ADDRESS_ALIAS
MACHINE_CLEARS.COUNT
MACHINE_CLEARS.MASKMOV
MACHINE_CLEARS.MEMORY_ORDERING
MACHINE_CLEARS.SMC
MEM_LOAD_UOPS_LLC_HIT_RETIRED.XSNP_HIT_PS
MEM_LOAD_UOPS_LLC_HIT_RETIRED.XSNP_HITM_PS
MEM_LOAD_UOPS_LLC_MISS_RETIRED.LOCAL_DRAM
MEM_LOAD_UOPS_RETIRED.L1_MISS
MEM_LOAD_UOPS_RETIRED.LLC_HIT_PS
MEM_LOAD_UOPS_RETIRED.LLC_MISS_PS
MEM_UOPS_RETIRED.ALL_STORES_PS
MEM_UOPS_RETIRED.SPLIT_LOADS_PS
MEM_UOPS_RETIRED.SPLIT_STORES_PS
OFFCORE_RESPONSE.DEMAND_DATA_RD.LLC_MISS.ANY_DRAM_0
OFFCORE_RESPONSE.DEMAND_RFO.LLC_HIT.HITM_OTHER_CORE_0
RESOURCE_STALLS.SB
RS_EVENTS.EMPTY_CYCLES
RS_EVENTS.EMPTY_END
UOPS_EXECUTED.CYCLES_GE_1_UOP_EXEC
UOPS_EXECUTED.CYCLES_GE_2_UOPS_EXEC
UOPS_EXECUTED.CYCLES_GE_3_UOPS_EXEC
UOPS_ISSUED.ANY
UOPS_RETIRED.RETIRE_SLOTS
T_C
Have attached the list of hardware event counters in this message.
David_A_Intel1
T C:
please check out this thread: http://software.intel.com/en-us/forums/topic/506796
yes, L2 cache is "unified" wrt the CPU.  Are you doing any GPU code excution?
