Analyzers
MKL in C#
Gianluca_G_
初學者
922 檢視
I'm testing MKL in a C# application.
I have to solve a linear system of complex matrix, so first of all I want to understand how the libraries works.
I'm not expert of c++, and Marshaling too so I have tried to define the dll as best as I could. I have used the library installed with Parallel Studio XE.
 The example that I have done, doesn't work is there any one that can help me to understand why?
  [SuppressUnmanagedCodeSecurity]
    internal sealed class MKLWrapper
        private MKLWrapper()
        [DllImport("mkl_rt.dll", ExactSpelling = true, SetLastError = false, CallingConvention = CallingConvention.Cdecl)]
        internal static extern int LAPACKE_zgesv(
            int matrix_layout,
            int n,
            int nrhs,
            [In, Out] Complex[,] input_matrix,
            int lda,
            [In, Out] int[] ipiv,
            [In, Out] Complex[,] b,
            int ldb
        public static void Test2()
            Complex[,] A = new Complex[3,3];
            Complex[,] b = new Complex[3,1];
            //r1
            A[0, 0] = 12;
            A[0, 1] = 1;
            A[0, 2] = 1;
            //r2
            A[1, 0] = 1;
            A[1, 1] = 12;
            A[1, 2] = 1;
            //r3
            A[2, 0] = 1;
            A[2, 1] = 1;
            A[2, 2] = 12;
            b[0, 0] = 16;
            b[1, 0] = 16;
            b[2, 0] = 16;
            int mat_layout = A.GetLength(0);
            int n = A.GetLength(0);
            int nrhs = 1;
            int lda = n;
            int ldb = n;
            int info = 1;
            int[] ipiv = new int;
            info = MKLWrapper.LAPACKE_zgesv(mat_layout, n, nrhs, A, lda, ipiv, b, ldb);
            if (info == 0)
                Console.WriteLine("Calculation completed!");
            else
                Console.WriteLine("Calculation Error!");
Thankyou very much
Gianluca
0 積分
2 回應
Gianluca_G_
初學者
921 檢視
this is the solution:
The function accept the input matrix in a vector form.
            int LAPACK_ROW_MAJOR = 101;
            int LAPACK_COL_MAJOR = 102;
            Complex[] A = new Complex[3*3];
            Complex[] b = new Complex[3];
            A[0] = 12; A[1] = 1; A[2] = 1; //r1
            A[3] = 1; A[4] = 12; A[5] = 1; //r2
            A[6] = 1; A[7] = 1; A[8] = 12; //r3
            b[0] = 16; b[1] = 16; b[2] = 16;
            int mat_layout = LAPACK_COL_MAJOR;
            int n = 3;
            int nrhs = 1;
            int lda = n;
            int ldb = n;
            int info = 1;
            if (info == 0)
            else
Kevin_O_Intel1
921 檢視
I think you are in the wrong forum. This is the Advisor XE forum.
You need the forum on MKL:
https://software.intel.com/en-us/forums/intel-math-kernel-library
Kevin
回覆
