Analyzers
5255 Discussions
Meaning of Poor Wait Time By Utilization
yixzhouNuro
Hi VTuen supports,
I want to understand a bit more on the vtune threading mode for and the Wait Time by Utilization column in the Bottom-Up section of the report, for an example, you can refer to the screenshot below:
I would like to understand the meaning of the Poor v.s. Idle utilization. In this example, is my application CPU compute intensive? My understanding is although I am polling / waiting on the condition variable, the process can yield to other CPU processes (although during this profiling run, i only had this one process). Will this behavior reflected in the profile? Or the long poor utilization bar we see here really means I am polling in a CPU intensive manner?
Thanks in advance,
yuzhang3_intel
A high thread wait time can cause poor CPU utilization. One common problem in parallel applications is threads waiting too long on synchronization objects that are on the critical path of application execution (for example, locks). Parallel performance suffers when waits occur while cores are under-utilized. Threading analysis helps to analyze thread wait time and find synchronization bottlenecks.
For details about the metric, you can refer to the guide:
https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2024-1/threading-efficiency-view.html
Poor vs. Idle, you can refer to the section of 'CPU Utilization' in guide:
https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2024-1/cpu-metrics-reference.html
Idle
Idle utilization. By default, if the CPU Time on all threads is less than 0.5 of 100% CPU Time on 1 core, such CPU utilization is classified as idle. Formula: Σi=1,ThreadsCount(CPUTime(T,i)/T) < 0.5, where CPUTime(T,i) is the total CPU Time on thread i on interval T.
Poor
Poor utilization. By default, poor utilization is when the number of simultaneously running CPUs is less than or equal to 50% of the target CPU utilization.
