Analyzers
Memory Error Analysis doesn't work
Christoph_S_
I'm using Intel Inspector XE 2017 Update 10 under Windows 10/64bit. I can't use any of the memory error analysis types provided.
If I select "Detect Leaks" I get the error message " The Byte Limit before reallocation knob value cannot be applied"
For Detect Leaks and Memory Access Problems I get "The Guard zone size knob value cannot be applied"
However I can copy one of the analysis types and use a custom analysis but it's awful slow and doesn't match the time overhead shown in the memory error analysis configuration.
Did I miss something here?
Thanks in advance!
Kevin_O_Intel1
Can you attach your result directory?
Thanks!
Christoph_S_
I don't have any results because I can't start any memory analysis the 'Start' button is greyed out.
Christoph_S_
I attached two screenshots that show that behavior.
Kevin_O_Intel1
Can you confirm the version you are using...
You mentioned: Intel Inspector XE 2017 Update 10
We  have only just released 2017 Update 3
Christoph_S_
Oh sorry that was a typo. I'm using Update 2. I tried to download the Update 3 but there is a problem with the update files. If I download with the Intel Software Manager I don't get the Windows version of the Inspector Update 3 but the Linux version. The same goes for the Intel Advisor 2017 Update 3.
Kevin_O_Intel1
Are you setting the INSPXE_EXPERIMENTAL environment variable?
Christoph_S_
Oh yes you're right. Don't know how this was set. Should I remove this variable?
