Analyzers
5328 Discussions
Mismatched allocation/deallocation
Nils_O_
I am getting a mismatched allocation/deallocation error. It's strange becamse it happens on new and delete lines. The deallocation error is on the line that is commented //DEALLOCATION, and the corresponding allocation error is on the comment //ALLOCATION. The code that causes this problem is below. I've attached the inspector results. Is this a legitimate error?
I suspect that it is because the program crashes in the Free() function when the destructor is called. However I'm pretty sure I'm doing the right thing.
m_list is a STL vector. I've also tried using a C++ array with the same results. Platform is VC 2008. I've tried compiling with Intel compiler and also with VC 2005 with the same crashing effect.
Thanks for any help.
Nils
[bash]
ICAPHPG::~ICAPHPG()
    Free();
ICAPHPG::ICAPHPG()
bool ICAPHPG::Allocate(int count_in)
    //m_list.reserve(count_in);
    //m_list.resize(count_in);
    m_hpgCount = count_in;
    return true;
void ICAPHPG::Free()
    for (unsigned int i = 0; i < m_list.size(); i++)
        if (m_list != NULL)
            delete m_list; //DEALLOCATE
bool ICAPHPG::loadHPG(int idx, const char* path)
    if (idx < 0 || idx >= m_hpgCount)
        return false;
    hpgns::CircularHPG* h = new hpgns::CircularHPG((char*)path); //ALLOCATE
    if (h == NULL)
        return false;
    else if (h->GetError())
        return false;
	m_list.push_back(h);
	return true;
[/bash]
