Analyzers
Missing Interactive Debugging "Debug This" Context Menu Item
John_D_9
I'm trying to attach my debugger to see a data race in the act, but I can't find the context menu item "Debug This Problem" explained in the documentation "About Investigating Problems Using Interactive Debugging" ( https://software.intel.com/en-us/node/528095 ):
2015-03-24 12_25_25-About Investigating Problems Using Interactive Debugging.png
Here is a screenshot with the context menu I expected would could contain the context menu item, but I don't see it.  Where is the "Debug This Problem" context menu item?
I am running Intel Inspector XE 2015 Update 1 (build 379161) on Windows 7 with Visual Studio Professional 2012 Update 4 (without Intel extensions installed with Visual Studio).  I collected the results like this:
inspxe-cl.exe -collect=ti3 -k use-maximum-resources=true -suppression-file=../default.sup -- foo.exe arg1 arg2
My application foo.exe is a release build -- I hope that doesn't somehow prevent interactive debugging from working (because I can't reproduce the data race in a small enough data set that could complete in a feasible amount of time in a debug build).
John
Mark_D_Intel
You need to be running Inspector integrated into Visual Studio for interactive debugging to work.
John_D_9
Thanks Mark, interactive debugging is working for me now.
