Analyzers
5317 Discussions
Not all threads are seen in the Hardware Event-Based Sampling mode
derevyannykh__mikhai
I use VTune for finding hotspots in my multithreading C++ app on Windows 10. Dutation time estimate - less than minute. Fast finalizion mode. Everything works fine in User-Mode sampling type (except the accuracy of measurement because it's a realtime simulation app). But when I try to use Hardware-Based sampling with intervals of sampling: 1ms, 0.1ms, 0.05ms - all threads except the main (which is the most interesting for researching) are correct, but the main thread is not visible. I tried to reinstalling and restarting Intel sampling drivers, everything were succusfelly set up. My Processor    Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz, 3600 Mhz, 8 Core(s), 8 Logical Processor(s). OS Version    10.0.17763 Build 17763. Intel VTune Amplifier 2019 Update 4 - 597835
What can me help with this problem? Thank you
Vladimir_R_Intel
Hi Mikhail,
Did you try both variants HW-based sampling with stacks and without? (it is important so as two different drivers work in these modes)
Is it possible to upload a reproducer here?
BR,
Vladimir
Thank you, for your answer. It helps. I have tried to use HW-based sampling without stacks and it started to work correctly, but... not the best stack information of course ( Unfortunatly, it's not possible to upload the reproducer, but I can try to code a new small project with a hope of reproducing the bug.
