Analyzers
5281 Discussions
PMU resource(s) currently being used by another profiling tool or process
Fabrizio_A_
The following command
mpirun -n 4 /opt/intel/vtune_amplifier_xe/bin64/amplxe-cl -collect-with runsa -knob event-config=FP_COMP_OPS_EXE.X87 -result-dir /home/fabrizio/Desktop/testt/ -- /home/fabrizio/Desktop/test
returns error in subject.
I tried a solution explained in an another post (./insmod -sep3 -r), but it seems not to be my case, because with ONE process I don't have error about PMU resource(s), but an error about "Failed to create a tb6 file".
How could I solve?
Thanks!
Peter_W_Intel
In general speaking, you can use "ps -ae | grep amplxe-cl" to find remained processes to kill them, then start a new session.
Also was it possible that some "defunct" process(es) remained? If so, you can use "ps -axl | grep defunct" then kill their parent processes.
You may do "rmmod_sep3" to uninstall drivers, then use "insmod_sep3" to install them again.
If above has no help, you might reboot the system:-(
Running mpirun with event-based collections, it is better to run such as:
amplxe-cl -collect-with runsa -knob event-config=FP_COMP_OPS_EXE.X87 -r result_dir -- mpirun -n 4 ./prog,
which will generate aggregated performance data (from multiple processes) in one result file. Does it solve your problem?
