Analyzers
5248 Discussions
cache miss and floating point operation
Fabrizio_A_
Salve a tutti,
sono interessato a valutare i cache miss e il numero di operazioni floating point con riferimento ad un programma MPI.
Da riga di comando ho provato:
mpirun -n 4 -l amplxe-cl -result-dir XXX -collect hotspots eseguibile
Il tipo di analisi "HOTSPOTS" è sufficiente per ottenere quanto desiderato?
Se sì. una volta aperti i risultati usando l'interfaccia grafica (amplxe-gui), dove sono reperibili le informazioni di cui sopra?
Se no, che comando è necessario utilizzare?
Grazie a tutti in anticipo!
Bernard
Valued Contributor I
Can you use Google translate?
David_A_Intel1
Hi Fabrizio!
Unfortunately, it is not that easy.  Modern processors have many ways of performing "float-point operations."  Therefore, I refer you to this article
Bernard
>>>FP_COMP_OPS_EXE.X87>>>
This option refers  only to x87 floating-point code. Modern compilers usually emit SSE/AVX code for target architecture which is newer that Pentium 3.
Bernard
What CPU do you have?
Bernard
Then you should look for SSE/AVX generated code unless you have some old library compiled into x87 code.
Peter_W_Intel
Command line is OK. I don't know what processor you used. You may use "amplxe-runss - event-list | grep FP_" to find them, which are supported by your processor.
About using events to measure cache miss, please read right tuning guides from this.
Bernard
>>>So, you need to know what processor you work,>>>
OP is using  Intel Core i7 3610QM.
Peter_W_Intel
@iliyapolak
It's hard to say that PMU event name is strictly same as doc described, that was why I provided the way to list supported events...you can find similar one (you want) from the list...for example, use key words "x87", "SSE_DOUBLE",etc to find
Bernard
Ok I understand it.
