- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Salve a tutti,
sono interessato a valutare i cache miss e il numero di operazioni floating point con riferimento ad un programma MPI.
Da riga di comando ho provato:
mpirun -n 4 -l amplxe-cl -result-dir XXX -collect hotspots eseguibile
Il tipo di analisi "HOTSPOTS" è sufficiente per ottenere quanto desiderato?
Se sì. una volta aperti i risultati usando l'interfaccia grafica (amplxe-gui), dove sono reperibili le informazioni di cui sopra?
Se no, che comando è necessario utilizzare?
Grazie a tutti in anticipo!
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Can you use Google translate?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Fabrizio!
Unfortunately, it is not that easy. Modern processors have many ways of performing "float-point operations." Therefore, I refer you to this article.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
>>>FP_COMP_OPS_EXE.X87>>>
This option refers only to x87 floating-point code. Modern compilers usually emit SSE/AVX code for target architecture which is newer that Pentium 3.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
What CPU do you have?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Then you should look for SSE/AVX generated code unless you have some old library compiled into x87 code.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Command line is OK. I don't know what processor you used. You may use "amplxe-runss - event-list | grep FP_" to find them, which are supported by your processor.
About using events to measure cache miss, please read right tuning guides from this.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
>>>So, you need to know what processor you work,>>>
OP is using Intel Core i7 3610QM.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
@iliyapolak
It's hard to say that PMU event name is strictly same as doc described, that was why I provided the way to list supported events...you can find similar one (you want) from the list...for example, use key words "x87", "SSE_DOUBLE",etc to find
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Ok I understand it.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
