Analyzers
Problem with Visual Studio 2019 plugin
Michal_Witanowski
I'm having trouble when trying to use VS2019 integration plugin. Every VTune window is blank and when I'm resizing it it's capturing the background leading to effect like this:
Looks like problem with this particualr plugin, because other plugins works fine and the standalone VTune UI works fine as well.
Any ideas what could be wrong?
Cheers,
Michal
Nika_D_Intel
Hello Michal Witanowski,
I see the same issue on my machine. It’s reproduced only with VS 2019 (VS 2017 is ok) and only on the first run. The next starting of VS 2019 does not have such issue. Do you see the same behavior?
 I’m going to continue the issue investigation.
Nika D
Nika_D_Intel
It looks like the issue is related to a new VS 2019 feature "Optimize rendering for screens with different pixel densities" (Tools->Options->General)
If this option is checked, there is a rendering problem with VS extension.
I am going to add fix for it on the future release
BR,
Nika
Michal_Witanowski
Thanks for providing workaround!
