Analyzers
5267 Discussions
Result file from Intel Inspector 2015 does not have call stack frames
Andrzej_S_
I have recently migrated from the Intel Inspector 2011 to Intel Inspector 2015 and I started to have problems with the result file that I generate using following cmd line command:
C:\Program Files (x86)\Intel\Inspector XE 2015\bin32\inspxe-cl.exe" -report=problems -suppression-file="C:/MySuppresion.sup" -format=xml -result-dir="C:/temp/result" -report-output="C:/temp/result\final_report"
The output file is generated and looks ALMOST the same like with one generated, by Intel Inspector 2011 with an exception, that it does not have frames from the call stack to the memory issue included. Previously I had .xml structure like:
<psets>
<pset>
<obs>
<stack>
<frame>
<frame>
</stack>
</obs>
</pset>
</psets>
Now I don't have <stack> and <frame> elements.
Does anyone know, whyt it is like that? And how can one get it back?
Keep well,
Andrzej
Peter_W_Intel
If I added option "-verbose", there were some stack info in outputs.
Peter_W_Intel
I think that option "-verbose" should address your question, also please use latest 2016 version.
Andrzej_S_
Thanks! I will try!
Andrzej_S_
If talking about 2016 version - do you have any list of bug fixes and new features comparing to 2015 version?
Peter_W_Intel
There is no detail list of bug fixes. You can find release notes here, see What's new
