Analyzers
5320 Discussions
Sampling Driver build fails
VTuneProfiler
I am using Vtune profiler 2021.7.1 version on Ubuntu machine 18/04 version
kernal version is 5.4.0-90-generic.
I want to perform energy analysis using socwatch collector for the system feature type(-f sys).
tried to build and install driver using following command line.
$ cd /opt/intel/oneapi/vtune/2021.7.0/sepdk/src/
$ ./build-driver -ni
$ ./insmod-sep -r
was able to build the drivers but during installation, I receive the below error. May I know how to resolve this
Tried to set kernel environment, I receive an error during 'make mrproper'
/usr/src/linux-headers-5.4.0-90-generic# make mrproper
fs/aufs/Makefile:3: fs/aufs/magic.mk: No such file or directory
make[2]: *** No rule to make target 'fs/aufs/magic.mk'. Stop.
scripts/Makefile.clean:67: recipe for target 'fs/aufs' failed
make[1]: *** [fs/aufs] Error 2
Makefile:1769: recipe for target '_clean_fs' failed
make: *** [_clean_fs] Error 2
Rahila_T_Intel
VTune 2021.9.0 is available now. Could you please uninstall the older version and try with the latest one?
You can download VTune 2021.9.0 as a standalone tool at https://www.intel.com/content/www/us/en/developer/articles/tool/oneapi-standalone-components.html#vtune or as part of oneAPI Base Toolkit 2021.4 at https://www.intel.com/content/www/us/en/developer/tools/oneapi/base-toolkit-download.html
If the issue still persist please let us know.
VTuneProfiler
While building the driver(./build-driver -ni) after installing the latest version I receive an error. But I'm able to run  SocWatch collecter after installation.
**************Built drivers are copied to /opt/intel/oneapi/vtune/2021.9.0/sepdk/src/socwatch/drivers directory ************
Done
mv: target 'socwatch2_15-x32_64-5-x32_64-5.4.0-90-genericsmp.ko' is not a directory
Makefile:208: recipe for target 'default' failed
make: *** [default] Error 1
Failed to build the drivers
Rahila_T_Intel
We could reproduce your issue. We are working on this internally, we will get back to you soon with an update.
Rahila_T_Intel
We are closing this thread as we connected internally and resolved the issue. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
UsingVtune
I have the same exact issue. It would be great if you could share the root cause.
