- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
could you try workaround now?
just replace mmap_sem on mmap_lock in /opt/intel/oneapi/vtune/2021.1-beta08/sepdk sources. I hope the fix must be in a couple files
Thanks, Kirill
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thanks for responding. I've already tried that route before posting.
I think the issue really boils down to missing struct and function declaration, like 'struct flush_tlb_info' and nmi_uaccess_okay() is no longer exposed when the macro 'MODULE' is defined, I assume this macro is always defined for kernel module building.
BTW, the definition is under arch/x86/include/asm/tlbflush.h
Would appreciate your suggestion on a workaround.
Alex
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Public kernel 5.8 support will be available in one of the next updates.
I suggest to use driverless collection now.
Sorry for inconvenience, Kirill
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Could you give us an update?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I think it's unresolved yet as seen from the reply of your colleague.
The beta09 release does not fix this issue.
Alex
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
We are forwarding the case to Subject Matter Experts so that they will let you know once it is corrected in the next updates.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Linux kernel 5.8 support is expected to be available in VTune 2021 Beta10 (and most probably in VTune 2020 U3).
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
