Analyzers
Symbol information not found
KKats1
VS 2015 Update 3, Intel Inspector XE 2016 Update 3 (build 460803), Windows 7 64 bit, analyzing a 64 bit program.
When I run the preset analysis "Locate memory problem" from the project node context menu, symbols for the program itself cannot be apparently loaded. When the program completes, a memory leak problem is reported in the Summary tab, but the lower pane says "Symbol information not found. Suggestion" etc. There is only the module name, and a hex address.
The program is built with debug information (I tried both /Zi and /ZI), and I can debug it just fine, the VS debugger loads symbols. Also, Inspector seems to report the location for another (probably bogus) problem of a mismatched allocation, pinpointing the location inside msvcp140d.dll all with source file and line number. It is only my own symbols that cannot be loaded.
How can I proceed troubleshooting from this point on?
Jackson_M_Intel
Is the module name for the memory leak reported by Inspector the main binary of your application or another dll? If it's a library, can you confirm that this library was build with symbols?
KKats1
It seems that the culprit is the /Debug:FASTLINK linker option that was added to Microsoft's linker in VS 2015 Update 1 (full details https://blogs.msdn.microsoft.com/vcblog/2015/10/16/debugfastlink-for-vs2015-update-1/)
Apparently. Inspector XE is unable to read symbols from a Partial PDB format generated with this option. When I switched to the old PDB generation, the error went away. (/DEBUG without a qualifier :FASTLINK).
I did not test this with Inspector 2017 yet.
Kirill_R_Intel
You are right. FASTLINK is not supported in our tools currently, you should disable it for Inspector analysis.
