Analyzers
5253 Discussions
Symbols not found - .pdb files
CL_V_
I would like to have more info about the pdb files which should be associated with the analysis.
  • Should the pdb file be the result from the same compilation that gave the .dll that I wish to inspect ?
  • If a lib is linked to the dll that i want to inspect, should i have the pdb for the lib ? should they be the exact pdb files that were generated at the same time as the lib that is linked ?
Thanks for your help
Peter_W_Intel
PDB file should be same of dll version, and source should not be "touched" - it means, date of source file is older than date of pdb/dll
If your lib has been linked into dll? Is it static linking? If so, lib's pdb will not be used; If not (dynamical link), please keep right pdb version for use.
