Hi all,
I find our application becomes very slow, then always has no response,when Use the Intel Inspector XE to coolect the memory leaks or thread errors.
Who met this kind of phenomenon?how I should Set the something?
thanks
Jesse
- Tags:
- CC++
- Debugging
- Development Tools
- Fortran
- Intel® Inspector
- Optimization
- Parallel Computing
- Vectorization
And, please use mi1 or ti1 instead of m3 or ti3, set stack depth as 1.
Tanks Peter Wang(Intel)
I Use mi1 or ti1 and Set stack Dept as 1,our project becomes quickly than before, but I Intentionally added a memory to constructor of one module, and Include this model.the Intel Inspector XE cannot find He memory leaks.
A::A(void) { for (int i =0; i<100;i++) { p= new QThread; } } -
Was it possible that return address is a global variable? Before application exits, there is no leak detected.
Can you try allocation memory for local (stack) variable?
I try allocation memory for local variable ,but Intel Inspector XE also cannot find the memory Leak in our project.
I try added the same code to Smaller project,it can Find.the memory leaks.
Was it due to no debug(symbol) info generated when compiling? Please use "-g" for Linux*, "/Zi /DEBUG" for Windows*.
Mybe I don't Set Optimization to Disabled(/Od),Now The Inspector XE Can Find this king of Memory Leaks.But It still Let our Application that Performance is very Low,I had Removed Modules do not to analyze.Especially Use mi2 or mi3
Using optimization switchers will not cause leaks not found. Anyway, it's good that you can find memory leaks for now.
You said, "...I Use mi1 or ti1 and Set stack Dept as 1,our project becomes quickly than before..." - if you still are not satisfied with this, you can use Collection Control APIs I posted at 02/05/2015 - 10:30 to reduce overhead.
Thanks .
I understand what you mean.I Will try it.
