Analyzers
The application was unable to start correctly (0xc0000005)
Philip_A_1
I am currently evaluating Inspector XE 2013 for use in an upcoming project.  I am experiencing difficulties when attempting to run the sample code ‘tachyon_insp_xe’.  Using Visual Studio 2013 I follow the instructions within the tutorial documentation for analysing threading errors, but every time the test I get the following error.
Find_and_fix_threading_errors.exe – Application Error
The application was unable to start correctly (0xc0000005). Click OK to close the application.
Bernard
Valued Contributor I
It looks like access violation error.Can you upload minidump file.Please do  not collect triage dump file.
Peter_W_Intel
I suppose that you may use command line to know if it was caused by application or Inspector XE.
1. If application works in command line, without using Inspector XE?
2. If application works with inspxe-cl: inspxe-cl -collect mi2|ti2 -- application
