Analyzers
Track the memory usage as a function of time
Kevin_Z_
Hi forum users,
I have an executable and I would like to track its memory usage as a function of time. I tried the "memory access" view point, but could not extract this information.
The only relevant post I found on this topic is an ancient one. https://software.intel.com/en-us/forums/intel-vtune-amplifier-xe/topic/309766
Is this possible with VTune? What is the correct analysis set up? Any comment is appreciated.
Kevin
David_A_Intel1
Hi Kevin:
Yeah, VTune Amplifier is not really the right tool to measure memory usage.  Amplifier's memory analysis is targeted at determining memory-related architecture issues that may inhibit hotspots from achieving their maximum performance.
For memory usage analysis, I would recommend the Intel® Inspector.  Inspector has the ability to track heap growth and display this in real-time as well as analyze it after collection completes.  Check out this article.  Intel Inspector XE is part of the Intel® Parallel Studio XE.
Peter_W_Intel
@Kevin Z
It depends on your demands - if you need to know memory growth in specific period, please use Inspector; if you need to know memory objects' cost (load & average latency) in specific function, please refer to this blog.
