Analyzers
5260 Discussions
Unable to install on Centos 6.5
Eli_Blackman
Using this version: vtune_amplifier_xe_2015_update1.tar.gz
Below is the output after running "install.sh":
Initializing, please wait...
*** glibc detected *** /data/home/elemental/vtune_amplifier_xe_2015_update1/./pset/32e/install: double free or corruption (!prev): 0x00000000169dad60 ***
======= Backtrace: =========
/lib64/libc.so.6[0x3333a75e66]
/lib64/libc.so.6[0x3333a789b3]
/data/home/elemental/vtune_amplifier_xe_2015_update1/./pset/32e/install(get_rpm_info+0x13b0)[0x45b1e0]
/data/home/elemental/vtune_amplifier_xe_2015_update1/./pset/32e/install(coex_apply_rpm_filter+0xd2)[0x419eb2]
/data/home/elemental/vtune_amplifier_xe_2015_update1/./pset/32e/install(coex_proceed_node+0x75b)[0x4191fb]
/data/home/elemental/vtune_amplifier_xe_2015_update1/./pset/32e/install(coex_diag_init+0x7d1)[0x41bc01]
/data/home/elemental/vtune_amplifier_xe_2015_update1/./pset/32e/install(actions_execute+0xb1)[0x412771]
/data/home/elemental/vtune_amplifier_xe_2015_update1/./pset/32e/install(_Z25sequence_execute_documentP9session_tP5cab_tP6node_tPcPS5_PiS6_S6_+0xca7)[0x460037]
/data/home/elemental/vtune_amplifier_xe_2015_update1/./pset/32e/install(sequence_execute+0x25c)[0x45c76c]
/data/home/elemental/vtune_amplifier_xe_2015_update1/./pset/32e/install(main+0x2a7f)[0x4104df]
/lib64/libc.so.6(__libc_start_main+0xfd)[0x3333a1ed5d]
/data/home/elemental/vtune_amplifier_xe_2015_update1/./pset/32e/install(__gxx_personality_v0+0xd2)[0x40d9ca]
======= Memory map: ========
00400000-004d8000 r-xp 00000000 fd:04 6426589                            /data/home/elemental/vtune_amplifier_xe_2015_update1/pset/32e/install
005d8000-005dc000 rw-p 000d8000 fd:04 6426589                            /data/home/elemental/vtune_amplifier_xe_2015_update1/pset/32e/install
005dc000-005dd000 rw-p 00000000 00:00 0
0216a000-169f7000 rw-p 00000000 00:00 0                                  [heap]
...<suppressed lines>...
7fea1c4f2000-7fea1c515000 rw-p 0017d000 fd:01 537839                     /tmp/install.wi62f7/activation/libcrypto.so.1.0.0./install.sh: line 574:  4119 Aborted                 (core dumped) "$pset_engine_cli_binary" --TEMP_FOLDER="$temp_folder" $params $@
We are able to install on Centos 7. Any suggestions?
Peter_W_Intel
Was it possible there was no 32bit glibc libraries - it seems that installer is 32e based. Maybe your Cent OS 7 have glibc both for 32bit & 64bit.
A quick solution is to copy whole vtune directory from 7.0 to 6.5 - then build/load vtune drivers under vtune_amplifier_xe_2015/sepdk/src.
Dmitry_P_Intel1
Hello Eli,
Could you please provide the following log file from your CentOS 6.5 box to look at:
$TMP/intel.pset.*
This will help us to explore on the issue.
Thanks & Regards, Dmitry
