Analyzers
Unable to load .pdb files after profiling using VS2019
bechard__malcolm
Hey,
After I profile my C++ application VTune just sits trying to load the .pdb for one of my libraries. It never moves past this .pdb. The .pdb it gets stuck on is random for each time I run. This application can be profiled without issue when compiled using VS2015 using the same Vtune version I've tried both compiling using /Zi and /Z7, but with the same results.
Behavior is identical when using the standalone VTune, or using the VS2019 integrated one. Anything I can do to help diagnose this?
Operating system and version
Windows 10
Tool version:
VTune 2020, Update 1. 607630
Compiler version:
MSVC 2019. 16.5.4
GNU Compiler Collection (GCC)* or Microsoft Visual Studio* version (if applicable)
MSVC 2019. 16.5.4, 14.25.28610
Denis_M_Intel
  Can you collect and upload VTune logs here? While VTune is hung finalizing a result, get the PID of the vtune-backend.exe (you can find it in the Task Manager -> Details, pid column) and run the following command:
<VTune_install_dir\bin64\amplxe-feedback.exe -create-bug-report=hang -no-system-info -dump-stack=<vtune-backend.exe PID>
It will create hang.zip archive with VTune logs and a stack dump in the working directory.
And what debug information option is used for building your libraries? Can you try to build them with "/DEBUG:FULL"
bechard__malcolm
Thank you for the note about /DEBUG! I was using /DEBUG:fastlink, which is one thing that is different when compiling with VS2019 vs VS2015. Changing it back to just /DEBUG fixes the issue.
Is this a known limitation?
Denis_M_Intel
Yes, there is a known limitation with /DEBUG:fastlink but VTune did not hang before. Thank you for reporting this issue.
ArunJ_Intel
Hey bechard, malcolm
Good to know the solution provided helps. Could you please confirm if we can close the case or is there anything else you need help with.
Arun Jose
bechard__malcolm
yep you can close it. I'll mention the program doesn't full hang, it just gets stuck trying to load the .dll/.pdb file .I can still somewhat interact with the window but I dont think the button really do much (such as cancel).
ArunJ_Intel
Thanks for the confirmation. We are closing the case. Please feel free to raise a new thread for further issues
