Analyzers
5255 Discussions
VS2012 VTune not allowing me to run Ivy Bridge Branch analysis?
T_C
I have an Ivy Bridge processor (i7 3520M) and in Visual Studio 2012 I have my VTune XE 2013 integrated. When I have the project in release mode, I start a new analysis but when I go to Branch Analysis under the Sandy/Ivy Bridge node it says:
"This analysis is only defined for processors......"
and doesn't allow me to run it.
My Visual Studio is running with Administrator privilleges.....
Bernard
Valued Contributor I
Does any other type of analysis work?
Peter_W_Intel
Also, you can try others from command line. Use "amplxe-cl -collect-list" to display all analysis types. Then try "amplxe-cl -collect analysis-type-n -- application". Note that analysis type you selected depends on your processor's microarchitecture.
Vitaly_S_Intel
Only "General Exploration" and "Bandwidth" analysis types are supported on Ivy Bridge and Haswell. Others can be used on Sandy Bridge only. Sorry for being confused - we're working on better structure of analysis types.
"General Exploration" should be able to identify most of HW issues.
T_C
Sorry for the delay guys,
I have also noticed sometimes when I try to run general analysis and logged in as an Administrator my application crashes. I get a messaged saying my application has stopped working. Its not random- it will happen every time (this is when running the normal hotspot analysis).
Does anyone know why?
Peter_W_Intel
Can you run general-exploration analysis with other simple app, e.g. Hello world?
Bernard
@Vitaliy
thanks for the explanation.
T_C
Ran it with a similar project and it works fine- so may be my current project is corrupt. Not sure if this matters, but I use intrinsics in the project which won't profile correctly? The project runs fine but I wonder if the intrinsics cause the weird error message when using VTune?
Peter_W_Intel
T C wrote:
Thanks for the update, that you can run GE analysis with other applications. Try your executable in command line (open cmd to run as administrator, run amplxe-vars.bat under vtune_install_dir) to very:
1. Program can run without using VTune analysis.
2. Program can run with user mode sampling collection, e.g. Hotspots analysis
3. Program can run with hardware event-based sampling, e.g. Advanced-hotspots analysis
4. Program can run with GE analysis, what is error message? And save result directory to submit this issue to Intel Premier.
