Analyzers
VTSS not installed for Vtune2017
Ewen_V_
Hi there,
I was wondering if VTSS (required for Advanced Profiling with callstacks) should work on my system.
Intel Xeon E5-2687W v3, Haswell-E/EP Socket 2011LGA
I installed Vtune as administrator and running the commands below (as admin) doesn't work, it fails to install the driver.
Any help/advice would be greatly appreciated.
​Thanks,
Ewen
C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE\bin32>amplxe-sepreg.exe -s
Checking sepdrv4_0 driver path...OK
Checking sepdrv4_0 service...
Driver status: the sepdrv4_0 service is running
Checking sepdal driver path...OK
Checking sepdal service...
Driver status: the sepdal service is running
Checking socperf2_0 driver path...OK
Checking socperf2_0 service...
Driver status: the socperf2_0 service is running
Checking VTSS++ driver path...FAILED
Checking VTSS++ service...
Driver status: the VTSS++ service is not running
C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE\bin32>amplxe-sepreg.exe -i -v
Stopping service sepdrv4_0...OK
Stopping service socperf2_0...OK
Copying file C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE\bin64\sepdrv\win7\socperf2_0.sys to C:\WINDOWS\System32\Drivers\socperf2_0.sys...OK
Installing service socperf2_0...OK
Warning: service socperf2_0 already exists
Starting service socperf2_0...OK
Writing startup key to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\socperf2_0...OK
Stopping service sepdrv4_0...Copying file C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE\bin64\sepdrv\win7\sepdrv4_0.sys to C:\WINDOWS\System32\Drivers\sepdrv4_0.sys...OK
Installing service sepdrv4_0...OK
Warning: service sepdrv4_0 already exists
Starting service sepdrv4_0...OK
Writing startup key to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\sepdrv4_0...OK
Stopping service sepdal...OK
Copying file C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE\bin64\sepdrv\win7\sepdal.sys to C:\WINDOWS\System32\Drivers\sepdal.sys...OK
Installing service sepdal...OK
Warning: service sepdal already exists
Starting service sepdal...OK
Writing startup key to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\sepdal...OK
Deleting system32/drivers/vtss.sys file...OK
Forming source path for vtss.sys...OK
Forming destination path for vtss.sys...OK
Copying file C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE\bin32\.\..\bin64\sepdrv\vtss.sys to C:\WINDOWS\system32\drivers\vtss.sys...OK
Installing and starting VTSS++ driver...
FAILED
Ewen_V_
More information, I'm running on Windows10 Vtune2017 Update2
Update 2 (build 499904) Copyright © 2009-2017 Intel Corporation. All rights reserved.
Ekaterina_L_Intel
Hi Ewen,
What is the Windows 10 build ID?
Regards, Katya
Ewen_V_
​Hi Katya,
Thanks for replying. I recently installed the Creators Build.
I'm running Windows 10 Pro
Version 1703
OS Build 15063.138
AFAIK Advanced Hotspots profiling used to work on this machine (on a previous build of Windows) with Vtune2016 Update4.
Ewen
Ekaterina_L_Intel
Hello Ewen,
Windows 10 build #15063 support by vtss driver is expected in coming Update 3 of VTune Amplifier 2017.
To unblock you now - please use updated drivers attached to the below forum thread with the same problem:
https://software.intel.com/en-us/comment/1903244#comment-1903244
Copy the attachment over <VTune>\bin64\sepdrv\vtss.sys”, then run “amplxe-sepreg.exe -i” from an administrative console to reload the driver.
Regards, Katya
Ewen_V_
Thank you for your help Katya.
The driver works on build #15063!
Ewen
