Analyzers
VTUNE don't enable Source/Assembly analysis
chang__yitao
Product: Intel®️ VTune™️ Amplifier update 2/update 4
Today When I use  GPU In-profiling mode, the VTUNE report a warning :"current graphics driver does not allow enable source/assembly analysis for OpenCL kernels running on intel graphics ."
However , i try some version graphics driver, the warning still exists.
What's wrong ? thanks a lot.
PC: CPU i7 - 8700 /  GPU UHD 630
drivers:24.20.100.6287
Egor_S_Intel1
It looks like the GPU driver doesn't set a flag which means that OpenCL runtime for GPU can provide debug information for OpenCL kernels. Therefore VTune shows this message and doesn't collect debug information for the kernels.
You can try to set this flag manually. You just need to add following registry values (also I've attached reg file that can do it):
HKEY_LOCAL_MACHINE\SOFTWARE\Intel\IGFX\OCL\DebugInfoSupport=dword:1
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Intel\IGFX\OCL\DebugInfoSupport=dword:1
And thank you for your report, we'll investigate why the flag is not set.
Egor_S_Intel1
chang__yitao
Hi, Thks a lot , now it can work.
