Analyzers
VTune 2016 Beta fails on Hotspot and Advanced Hotspot
Towie__Ewan
I am having endless problems getting the VTune 2016 Beta to profile my application. The application seg faults when run in VTune with a completely unhelpful stack trace despite debugging symbols being available. The application runs fine both through my debugger and on the command line.
I am currently trying to work through its warnings to figure out what might be the problem and one thing that sticks out is the following
strace: /opt/intel_beta/vtune_amplifier_xe_2016.0.1.414512/lib64/pinruntime/glibc/libc.so.6: version `GLIBC_2.4' not found (required by strace)
Checking the folder above, libc.so.6 is a symbolic link to libc-2.3.4.so in the same folder. What worries me is that VTune is using the system strace tool and my system is on libc.2.12.so.
For reference I am running on CentOS 6.6, VTune supports CentOS 6.5 but glibc hasn't changed between these versions.
Help desperately needed!
Ewan
David_A_Intel1
Hi Ewan:
I just verified that the __itt_resume() API works on Linux.  Please ensure that the API is being called and that you are using the "Start Paused" button or option to start the collection.
Towie__Ewan
I am definitely calling the API and using the Start Paused button. As I say, the collection control API works perfectly with the Basic Hotspots analysis and only fails to resume under Advanced Hotspots. Oddly, the Advanced Hotspots seems to correctly catch the pause call?
I am accessing the ITT notify library through the following USE command in my Fortran code:
USE ittnotify, ONLY: itt_pause, itt_resume
and then calling the routines with:
CALL itt_resume()
CALL itt_pause()
I am directly linking and including the ittnotify module by adding the following compilation command to my compile line:
-I/opt/intel_beta/vtune_amplifier_xe/include/intel64
and adding the following link command to my link line:
/opt/intel_beta/vtune_amplifier_xe/lib64/libittnotify.a
Ewan
David_A_Intel1
Okay, I finally got confirmation that this was a defect in the beta code and should be addressed in the production release.  Basically, the API works except when using the "Start Paused" functionality. :(
One workaround would be to insert a call the the pause() routine as the first statement in your app.
Towie__Ewan
Haha, ok that makes total sense ;) I think I already have a pause() call at the start of the code so I shall try just using the "Start" button.
Am hoping you get the Concurrency mode bug resolved soon, this is where I want to focus my attention for the next stage of the optimisation.
Ewan
