Analyzers
5285 Discussions
VTune 2022.2.0 vtsspp driver failed to load on Ubuntu 18.04
M_Stickland
Hi, I have installed VTune 2022.2.0 using the Standalone/Offline installer on Ubuntu 18.04, kernel version 5.4.0-107-generic.
After many attempts, I'm unable to install the vtsspp driver.
1. I attempted to build Sampling Drivers normally...
Output from attempting to build all the Sampling Drivers:
ubuntu@ubuntu:/opt/intel/oneapi/vtune/2022.2.0/sepdk/src$ sudo ./build-driver
[sudo] password for ubuntu:
C compiler to use: [ /usr/bin//gcc ]
C compiler version: 7.5.0
Make command to use: [ /usr/bin//make ]
Make version: 4.1
Kernel source directory: [ /lib/modules/5.4.0-107-generic/build ]
Kernel version: 5.4.0-107-generic
Cleaning workspaces ...
Done
Building socperf driver ...
Done
Building sep driver ...
Done
Building pax driver ...
Done
Building vtsspp driver ...
make[1]: Entering directory '/opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp'
make[2]: Entering directory '/usr/src/linux-headers-5.4.0-107-generic'
  TEST    VTSS_AUTOCONF_ACCESS_OK_TWO_ARGS=yes
  TEST    VTSS_AUTOCONF_CPULIST_SCNPRINTF=no
  TEST    VTSS_AUTOCONF_CURRENT_KUID_KGID=yes
  TEST    VTSS_AUTOCONF_DUMP_TRACE_HAVE_BP=no
  TEST    VTSS_AUTOCONF_FLUSH_TLB_INFO=yes
  TEST    VTSS_AUTOCONF_FOR_EACH_KERNEL_TRACEPOINT=yes
  TEST    VTSS_AUTOCONF_HLIST_NODE_ITER=no
  TEST    VTSS_AUTOCONF_INLINE_COPY_FROM_USER=no
  TEST    VTSS_AUTOCONF_JPROBE=no
  TEST    VTSS_AUTOCONF_KAISER=no
  TEST    VTSS_AUTOCONF_KERNEL_HEADERS=yes
  TEST    VTSS_AUTOCONF_KERNEL_READ_WRITE=yes
  TEST    VTSS_AUTOCONF_KMAP_ATOMIC_ONE_ARG=yes
  TEST    VTSS_AUTOCONF_KRETPROBE_INSTANCE_TASK_ARG=yes
  TEST    VTSS_AUTOCONF_KTIME_EQUAL=no
  TEST    VTSS_AUTOCONF_KTIME_GET_TS64=yes
  TEST    VTSS_AUTOCONF_MMAP_LOCK=no
  TEST    VTSS_AUTOCONF_MODULE_CORE_LAYOUT=yes
  TEST    VTSS_AUTOCONF_MODULE_MUTEX=yes
  TEST    VTSS_AUTOCONF_NMI_UACCESS=yes
  TEST    VTSS_AUTOCONF_PREEMPT_NOTIFIER_CONTROL=yes
  TEST    VTSS_AUTOCONF_PROCFS_OPS=no
  TEST    VTSS_AUTOCONF_PROCFS_OWNER=no
  TEST    VTSS_AUTOCONF_PROCFS_SET_USER=yes
  TEST    VTSS_AUTOCONF_PROCFS_SUBTREE=yes
  TEST    VTSS_AUTOCONF_SET_FS=yes
  TEST    VTSS_AUTOCONF_SI_MEM_AVAILABLE=yes
  TEST    VTSS_AUTOCONF_STACKTRACE_OPS=no
  TEST    VTSS_AUTOCONF_STACKTRACE_OPS_ADDRESS_INT=no
  TEST    VTSS_AUTOCONF_STACKTRACE_OPS_WALK_STACK=no
  TEST    VTSS_AUTOCONF_STACKTRACE_OPS_WALK_STACK_TASK_ARG=no
  TEST    VTSS_AUTOCONF_STACKTRACE_OPS_WARNING=no
  TEST    VTSS_AUTOCONF_SYSTEM_UNBOUND_WQ=yes
  TEST    VTSS_AUTOCONF_TASK_STRUCT_HIDDEN_STATE=no
  TEST    VTSS_AUTOCONF_TIMER_SETUP=yes
  TEST    VTSS_AUTOCONF_TRACE_SCHED_SWITCH_NO_ARG=no
  TEST    VTSS_AUTOCONF_TRACE_SCHED_SWITCH_PREEMPT_ARG=yes
  TEST    VTSS_AUTOCONF_TRACE_SCHED_SWITCH_RQ_ARG=no
  TEST    VTSS_AUTOCONF_TRACEPOINT_PROBE=yes
  TEST    VTSS_AUTOCONF_USER_MODE_VM=no
  TEST    VTSS_AUTOCONF_VSYSCALL_ADDR=yes
  TEST    VTSS_AUTOCONF_X86_UNIREGS=yes
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/cmd.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/dsa.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/ipt.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/kmem.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/kpti.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/ksyms.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/lbr.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/mmap.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/modcfg.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/module.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/nmiwd.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/pcb.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/pebs.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/pmi.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/pmu.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/probe.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/procfs.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/record.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/sched.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/stack.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/target.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/task.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/task_map.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/transport.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/unwind.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/user_vm.o
  LD [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/vtsspp.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/vtsspp.mod.o
  LD [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp/vtsspp.ko
make[2]: Leaving directory '/usr/src/linux-headers-5.4.0-107-generic'
cp -f vtsspp.ko vtsspp-x32_64-5.4.0-107-genericsmp.ko
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2022.2.0/sepdk/src/vtsspp'
Done
Building socwatch driver ...
Building drivers for Linux target
-n switch is deprecated. Now it does not have any effect.
/lib/modules/5.4.0-107-generic/build will be used as the kernel build directory
Removing previously built driver and scripts from /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/drivers
mkdir: cannot create directory ‘/opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/drivers’: File exists
-c /usr/bin//gcc -l -k /lib/modules/5.4.0-107-generic/build will be used to build the SoCWatch driver
************ Building socwatch2_15.ko driver ************
Using C compiler = /usr/bin//gcc
Using kernel build dir = /lib/modules/5.4.0-107-generic/build
No module symvers file found
Using common inc dir = /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/../common/include
"/lib/modules/5.4.0-107-generic/build/include/linux/cpufreq.h" exists!
Using file name sw_driver
Make args = KERNEL_SRC_DIR=/lib/modules/5.4.0-107-generic/build CPUFREQ_FIX_BACKPORTED=1 DO_DEBUG_BUILD=0 DO_PROFILING=0 COMMON_INC_DIR=/opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/../common/include MODULE_SYMVERS_FILE= FILE_NAME=sw_driver
make[1]: Entering directory '/opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver'
make -C /lib/modules/5.4.0-107-generic/build M=/opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver clean
  CLEAN   /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/Module.symvers
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver'
DO_SOCPERF=0
DO_DRIVER_PROFILING=0
INCDIR_1=/opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/../common/include
make -C /lib/modules/5.4.0-107-generic/build M=/opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver modules PWD=/opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_driver.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_hardware_io.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_output_buffer.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_tracepoint_handlers.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_collector.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_mem.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_internal.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_file_ops.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_ops_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_trace_notifier_provider.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_reader.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_telem.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_pmt.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_counter_list.o
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/./src/sw_pci.o
  LD [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.o
  MODPOST 1 modules
  CC [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.mod.o
  LD [M]  /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/socwatch_driver/socwatch2_15.ko
************ Built drivers are copied to /opt/intel/oneapi/vtune/2022.2.0/sepdk/src/socwatch/drivers directory ************
Done
Done building the drivers
ubuntu@ubuntu:/opt/intel/oneapi/vtune/2022.2.0/sepdk/src$ sudo ./rmmod-sep
Warning:  the following driver(s) were not found loaded in the kernel:  sep5.
ubuntu@ubuntu:/opt/intel/oneapi/vtune/2022.2.0/sepdk/src$ sudo ./insmod-sep
PYTHON is set to python3
---------------------    Loading PAX driver    ---------------------
Checking for PMU arbitration service (PAX) ... not detected.
Attempting to start PAX service ...
Executing: insmod ./pax/pax-x32_64-5.4.0-107-genericsmp.ko
Setting group ownership of devices to group "vtune" ... done.
Setting file permissions on devices to "660" ... done.
The pax driver has been successfully loaded.
---------------------  Loading SOCPERF driver  ---------------------
Checking for socperf driver ... not detected.
Attempting to start socperf service ...
Executing: insmod ./socperf/src/socperf3-x32_64-5.4.0-107-genericsmp.ko
The socperf3 driver has been successfully loaded.
---------------------    Loading SEP driver    ---------------------
Executing: insmod ./sep5-x32_64-5.4.0-107-genericsmp.ko
The sep5 driver has been successfully loaded.
---------------------  Loading VTSSPP driver  ---------------------
Checking for vtsspp driver ... not detected.
Executing: insmod ./vtsspp/vtsspp-x32_64-5.4.0-107-genericsmp.ko gid=1001 mode=0660 ksyms="ffffffff8a754a60"
insmod: ERROR: could not insert module ./vtsspp/vtsspp-x32_64-5.4.0-107-genericsmp.ko: Invalid parameters
Error:  vtsspp driver failed to load!
You may need to build vtsspp driver for your kernel.
Please see the vtsspp driver README for instructions.
--------------------- Loading SOCWATCH driver ---------------------
Checking for socwatch driver ... not detected.
Executing: insmod ./socwatch/drivers/socwatch2_15-x32_64-5.4.0-107-genericsmp.ko
Setting group ownership of device file to group "vtune" ... done.
Setting file permissions of device file to "660" ... done.
The socwatch driver has been successfully loaded.
NOTE:
The driver is accessible only to users under the group vtune.
Please add the users to the group 'vtune' to use the tool.
To change driver access group, reinstall the driver using -g <desired_group> option.
NOTE:
Please add the users to the group vtune to use the tool.
To change driver access group, reload the driver using -g <desired_group> option.
Result #1 is that the vtsspp driver failed to load.
2. I followed the instructions in .../sepdk/src/vtsspp/README.txt
Output from attempting to build the vtsspp driver for my kernel:
ubuntu@ubuntu:/opt/intel/oneapi/vtune/2022.2.0/sepdk/src$ sudo ./vtsspp/build-driver
Options in brackets "[ ... ]" indicate default values
that will be used when only the ENTER key is pressed.
./vtsspp/build-driver: 334: cd: can't cd to ./vtsspp
Done
Done
Done
Directory to install vtsspp driver: [ /opt/intel/oneapi/vtune/2022.2.0/sepdk/src ]
ubuntu@ubuntu:/opt/intel/oneapi/vtune/2022.2.0/sepdk/src$ sudo ./vtsspp/rmmod-vtsspp
Warning:  no vtsspp driver was found loaded in the kernel.
ubuntu@ubuntu:/opt/intel/oneapi/vtune/2022.2.0/sepdk/src$ sudo ./vtsspp/insmod-vtsspp
Executing: insmod ./vtsspp/vtsspp-x32_64-5.4.0-107-genericsmp.ko gid=0 mode=0660 ksyms="ffffffff8a754a60"
ubuntu@ubuntu:/opt/intel/oneapi/vtune/2022.2.0/sepdk/src$ sudo ./vtsspp/insmod-vtsspp -g vtune -r
Result #2 is that the vtsspp driver failed to load, again.
I have a VTune group that contains both my normal ubuntu user and the root user:
ubuntu@ubuntu:$ grep '^vtune:' /etc/group
vtune:x:1001:ubuntu,root
I've run the vtune-self-checker and attached the output log.txt file to this post.
Please help, I'm at a loss as to what I can try next.
Thank you.
nil59
I have exactly the same problem with ubuntu 20.04.
kernel 5.4.0-135
Aliaksei
Similar issue wmWare Ubuntu 22.04.1 LTS , build was successfull and install:
sudo ./insmod-sep -r -g vtune
...everything before success and then..
Executing: insmod ./vtsspp/vtsspp-x32_64-5.15.0-57-genericsmp.ko gid=1001 mode=0660 ksyms="ffffffffa87984e0"
insmod: ERROR: could not insert module ./vtsspp/vtsspp-x32_64-5.15.0-57-genericsmp.ko: Invalid parameters
./socwatch/insmod-socwatch: 312: [: ./socwatch/drivers/socwatch2_15-x32_64-5.15.0-56-genericsmp.ko: unexpected operator
Executing: insmod ./socwatch/drivers/socwatch2_15-x32_64-5.15.0-56-genericsmp.ko
socwatch2_15-x32_64-5.15.0-57-genericsmp.ko
insmod: ERROR: could not insert module ./socwatch/drivers/socwatch2_15-x32_64-5.15.0-56-genericsmp.ko: Invalid parameters
Error: socwatch driver failed to load!
You may need to build socwatch driver for your kernel.
Please see the socwatch driver README for instructions.
