On Win7 64 bit, VTune Amplifier XE 2013 locks up on exit and needs to be terminated nearly every time I use it on a medium sized problem. Is this a known issue?
And while I am here, I would like to say that the "new" user interface of the start page with a few "clickable" links in the middle of a blank page is a huge backward step.
I never heard this before, what are the specific things in your system environment?
You may try latest product VTune(TM) Amplifier XE Update 3, to verify again.
>>>n Win7 64 bit, VTune Amplifier XE 2013 locks up on exit and needs to be terminated nearly every time I use it on a medium sized problem. Is this a known issue?>>>
Did you receive any error messages when VTune hungs?
Unfortunately no error messages. I have to force-quit the process from task manager.
>>>Unfortunately no error messages. I have to force-quit the process from task manager.>>>
I'd like to recommend you to dump the hung process with the AD plus tool.You can download it as a part of windows debugging tools.
Other option is to use windbg and break into hung process with the !runaway metacommand.
