- « Previous
- Next »
Jay I'm concerned you couldn't open a case. Can you please try again, and note that alphabetically, the product is not under "V" for VTune, but "B" for Beta.
What do you think?
cheers
jdg
JP
So there is a bit of hope still...
I'm usingVTServer from VTune Analyzer7.1 Beta.
I guess you're implying Thread View should work with standalone Analyzer 2.0 for Linux. Is that right?
The 2004 LinuxWorld Conference and Expois January 21-23 at New York City'sJavits Center. If you plan on attending,stop by the Intel booth, #645, and check out our showcase ofthe latest Intel software development tools and services.
We are alsoholdinga Linux software development tools Birds-of-a-Feather(BOF)on Wednesday, January 21, 5:30 PM to 7:00 PM in room 1E07. Stop byand receive a special gift!
Linux* Compilers and Profiling Tools: Do they REALLY Make a Difference?
If you've ever done any Linux software optimization or are thinking about it,this session is for you. Industry experts will be on hand to fuel discussion around common issues and use of tools in a variety of development environments.
Learn how to identify your current optimization challenges and hear how others are successfully managing theirs
Get with your fellow travelers to learn which tools work and which don't
Share information about best known practices and related costs
Profiling tools can substantially reduce your development time. Don't let your busy schedule writing and rewriting code keep you away.For more information and to register for this BOF seminar, visit http://www.linuxworldexpo.com/linuxworldny/V40/conference/session.cvn?eID=388.
If you havent registered for the 2004 LinuxWorld Conference and Expo, do it now: http://www.linuxworldexpo.com/linuxworldny/V40/index.cvn. Join your fellow travelers and industry experts to get the latest on software development tools for Intel-based Linux development.
Hello Henric,
You've hit the nail on the head already: the tarball you downloadedvt_cli_2.0.348.tar is not beta, it's final product. Beta licenses don't work with final product.
Message Edited by jdgallag on 01-28-2004 10:41 AM
I'm trying to use the sampling feature of vtune to profile my application built with icc but I keep getting "no symbols were found" when I try to view the hotspot function results for a shared object (.so) module.
I've boiled this down to a simple test case which works fine with gcc but not with icc.
$ cat foo.h
#ifndef FOO_H
#define FOO_H
void foo ();
#endif
(please substitute "less-than" for appropriate symbol, the forum things I'm trying to post html when I have an angle bracket)
$ cat foo.c
#include "foo.h"
void foo () {
int i;
for( i = 0; i less-than 100000000; i++) {
$ cat main.c
#include "foo.h"
int main () {
int i;
for( i = 0; i less-than 5; i++) {
foo();
$ icc -g -shared -fPIC foo.c -o libfoo.so
$ icc -g -c main.c -o main.o
$ icc main.o -lfoo -L.
$ vtl activity -c sampling -app a.out run
[ vtune runs ]
$ vtl show -hf -mn libfoo.so
[ .. event information .. ]
No symbols were found
If I compile *exactly* the same way using gcc instead of icc I will get the desired results (i.e. I get event %'s about my functions). I've also tried compiling with gcc using the -gdwarf-2 flag in place of the -g flag which also gives the desired results.
Why does this not work with the intel compiler? Is VTune not capable of profiling an application built this way? Does anybody have any ideas what could be wrong?
Thank You,
Nathan
some info:
icc: Version 8.0
gcc: Version 2.96
OS : RedHat 7.3 [kernel 2.4.18-3] (also tried on RHAS2.1)
Hey Nathan,
VERY interesting problem description.
But before we dig in too far, which version of vtune are you using?
$ vtl version
Build: 348
http://www.intel.com/software/products/opensource/vdk/
However, it requires a patch to kernel 2.6.0-test5 (i.e., users must rebuild that kernel with the patch, and we include the patch along with the VDK sources).
We have not tested/ported VDK driver to any version of kernel 2.6.x (patched or otherwise) on Itanium Linux as yet.
I hope this helps.cheers
jdg
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
- « Previous
- Next »
