Analyzers
5341 Discussions
VTune cannot detect local machine configuration
Daniel_D
unfortunately I run into issues starting vtune. I use the latest oneAPI (20242.2.1)
No matter if I run vtune from vs2022 or from command line I do get this error. running on windows 11 with all updates.
Any idea what I'm doing wrong here?
Here some additional information:
C:\Windows\System32>"C:\Program Files (x86)\Intel\oneAPI\vtune\2024.2\bin64\sep" -version
Sampling Enabling Product Version: 5.48 Beta built on Jul 29 2024 12:31:32
SEP Driver Version: 5.48 Beta (public)
PAX Driver Version: 1.0
Platform type: 122
CPU name: Intel(R) microarchitecture code named Coffeelake
PMU: skylake
Driver configs: Maskable Interrupt, OFFCORE OFF (by OS security), REGISTER CHECK ON
Virtualization platform: Host VM on Hyper-V with VBS enabled
Copyright(C) 2007 Intel Corporation. All rights reserved.
Just noticed: advisor didn't start at all from VS2022 (EXTENSIONS->Intel->Analyze performance with Intel Advisor).
yuzhang3_intel
The CPU is 9th Gen Intel® Core™ processor?  If yes, you can try it below.
https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html
yuzhang3_intel
Can you check if there are files in the below path?
Update configuration: tmp directory = R:\Temp\amplxe-tmp-Daniel Droste
Daniel_D
The folder is empty. I can give you remote desktop access if you need.....
yuzhang3_intel
I am not sure I can access your machine via the company intranet.
yuzhang3_intel
Can you capture the log again using the administrator?
Daniel_D
sure.
yuzhang3_intel
It is strange. From your log on the left in the screenshot below, I didn't see the administrator absent. On the right, you can see the administrator absent even when I open the console window, not as an administrator.
Daniel_D
yuzhang3_intel
Could you confirm if you run the command line as administrator?
Daniel_D
 - yes. I can.
yuzhang3_intel
Ok, I need to do a further investigation. Thanks.
yuzhang3_intel
There seems to be Metrics Discovery library crash on the system. Could you please specify the exact graphics driver version and try it?
Daniel_D
My system holds a 1050Ti, 1070 and a 3060 - as well as a i9 with integrated iGPU (UHD 630). Which driver version do you need? The nvidia runs with one of the latest driver 560.81, the Intel with 30.0.100.9805
Is that what you asking?
yuzhang3_intel
Daniel_D
that did the trick! Its working now. Thanks a lot.
I wonder why I need the latest intel gpu driver to use vtune? Does that mean that I cannot use vtune if I have a system without iGPU?
Thanks again
yuzhang3_intel
Good question, I need to do further investigation. At least it works now.
