Analyzers
5307 Discussions
VTune command line Error 0x40000028 (Reporter error)
Roman_H
after upgrading from 2022.1 to the current 2022.4.1 I cannot use the command line anymore.
It is executing the VTune hotspot analysis but stops at generating the report.
This is a typical output:
vtune: Collection stopped.
vtune: Using result path `c:\Users\rhimmes.INFORM\vtune\r002hs'
vtune: Executing actions 19 % Resolving information for `ucrtbase.dll'
vtune: Executing actions 19 % Resolving information for `KERNELBASE.dll'
vtune: Finalization may slow down when loading files from the symbol server specified in the project properties.
vtune: Executing actions 75 % Generating a report
Error: Unexpected report template location
vtune: Executing actions 100 % done
vtune: Error: 0x40000028 (Reporter error)
I have already tried uninstalling and reinstalling vtune again.
What else can I do?
AthiraM_Intel
Could you please share the OS and hardware details?
Also share the analysis type and the command you used.
Roman_H
thank you for your reply:
* The OS is Windows Server 2022
* The error is aready being displayed after collecting the data via
vtune -collect hotspots <myexecutable.exe>
and also if you try to create *any* report afterwards.
BUT I could solve the issue by changing the path variable from:
set PATH=C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64;%PATH%
to
set PATH=c:\Program Files (x86)\Intel\oneAPI\vtune\2022.4.1\bin64;%PATH%
So it seems that the Symlink does not work on Windows Sever 2022 with the command line
For me, the issue is solved, I can live with this workaround.
Thank you again.
AthiraM_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
