Analyzers
5248 토론
VTune error: This analysis type is not applicable to the current machine microarchitecture.
-Light-
초보자
9,830 조회수
Hi, all.
When I launch VTune for Fortran project, see error:
This analysis type is not applicable to the system because VTune Profiler cannot recognize the processor. If this is a new Intel processor, please check for an updated version of VTune Profiler. If this is an unreleased Intel processor, please contact Online Service Center for an NDA product package.
CPU is Intel(R) Core(TM) i7-12700H 16G RAM
VTune Profiler 2024.1
I saw the same issue mentioned in a related thread, but that was for the i7-2600K. I'm using the 12th Gen Intel® Core™ i7-12700H processor and the latest version of VTune 2024.1. Why am I still experiencing this problem?
What can be done to fix this?
Thanks in advance
30 응답
yuzhang3_intel
중재자
6,866 조회수
Is it Windows 11? The current VTune release doesn't support some of the latest Windows 11 builds. A similar question was discussed on the forum.
https://community.intel.com/t5/Analyzers/VTune-vtss-sample-driver-don-t-support-Windows-11-24H2-yet/m-p/1587035#M24535
0 포인트
-Light-
초보자
6,859 조회수
No, I'm actually using Windows 10 IoT Enterprise 22H2
0 포인트
-Light-
초보자
6,843 조회수
I'm actually using Windows 10 IoT Enterprise 22H2, Does the current Vtun release also not work with Windows 10 IoT Enterprise 22H2?
0 포인트
yuzhang3_intel
중재자
6,833 조회수
It should support for 22H2. Could you check if the VTune driver is ready?
C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64>sep.exe -version
WARNING: Windows Defender Antivirus may interfere PMU counter accesses which can fail to collect data in the collection. Please turn off Real Time Protection toggle switch and re-run the collection. Refer to SEP User Guide for more details.
Sampling Enabling Product Version: 5.43 built on Nov 1 2023 22:56:57
SEP Driver Version: 5.47 (public)
PAX Driver Version: 1.0
Platform type: 148
CPU name: Intel(R) microarchitecture code named Alderlake-P
PMU: alderlake
Driver configs: Maskable Interrupt, OFFCORE OFF (by OS security), REGISTER CHECK ON
Virtualization platform: Host VM on Hyper-V with VBS enabled
Copyright(C) 2007 Intel Corporation. All rights reserved.
and check the status and install driver when needed.
C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64>amplxe-sepreg.exe -s
Checking sepdrv5 driver path...OK
Checking sepdrv5 service...
Driver status: the sepdrv5 service is running
Checking sepdal driver path...OK
Checking sepdal service...
Driver status: the sepdal service is running
Checking socperf3 driver path...OK
Checking socperf3 service...
Driver status: the socperf3 service is running
Checking vtss driver path...OK
Checking vtss service...OK
C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64>amplxe-sepreg.exe -i
0 포인트
-Light-
초보자
6,824 조회수
The VTune driver does not seem to be ready.
I ran C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64> sep.exe-version without any output.
0 포인트
-Light-
초보자
6,823 조회수
Failed to start vtss service; error code: 1058
0 포인트
yuzhang3_intel
중재자
6,828 조회수
Install the driver following the below command (run as administrator in cmd console)
and then check if it is ready.
0 포인트
-Light-
초보자
6,824 조회수
I rebooted my computer but the VTune driver still doesn't seem to be ready.
0 포인트
-Light-
초보자
6,810 조회수
I used the commands as administrator in cmd console
C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64> amplxe-sepreg.exe -s
The driver was successfully installed
and I restarted my computer
but ran C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64> sep.exe-version still no output.
0 포인트
yuzhang3_intel
중재자
6,813 조회수
Please post the output in the process of driver installation.
0 포인트
yuzhang3_intel
중재자
6,800 조회수
Let me check if IoT Enterprise is supported. It looks like the version doesn't support from system requirement.
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/vtune-profiler-system-requirements.html
  • Supported operating systems:
    • Microsoft* Windows 11 23H2,
    • Microsoft* Windows Pro & Enterprise 10, 11
    • Microsoft* Windows 10 22H2, 11 22H2, 11 23H2
    • Microsoft* Windows Server 2019,  2022
0 포인트
yuzhang3_intel
중재자
6,792 조회수
Could you please post the output from the self-check utility? Run as administrator.
C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64>vtune-self-checker.bat
0 포인트
-Light-
초보자
6,789 조회수
You should have said
C:\Program Files (x86)\Intel\oneAPI\vtune\2024.1\bin64>vtune-self-checker.bat
instead of
The output is as follows:
Intel(R) VTune(TM) Profiler Self Check Utility
Copyright (C) 2009 Intel Corporation. All rights reserved.
Build Number: 627630
HW event-based analysis (counting mode)
Example of analysis types: Performance Snapshot
Collection: Fail
vtune: Error: This analysis type is not applicable to the system because VTune Profiler cannot recognize the processor.
If this is an old Intel processor, please refer to the minimum hardware requirements in the release note. If this is a n
vtune: Error: This analysis type is not applicable to the current machine microarchitecture.
Instrumentation based analysis check
Example of analysis types: Hotspots and Threading with user-mode sampling
Collection: Fail
vtune: Error: Option 'platform-type' received value from the next argument: '--search-dir', but it seems to be an option
. Use '-option=value' declaration form or make sure that value is not missed
vtune: Warning: Microarchitecture performance insights will not be available. Make sure the sampling driver is installed
and enabled on your system.
HW event-based analysis check
Example of analysis types: Hotspots with HW event-based sampling, HPC Performance Characterization, etc.
Collection: Fail
Example of analysis types: Microarchitecture Exploration
Collection: Fail
vtune: Error
0 포인트
yuzhang3_intel
중재자
6,788 조회수
Thanks, please attach the log file.
0 포인트
-Light-
초보자
6,780 조회수
C:\Program Files (x86)\Intel\oneAPI\vtune\2024.1\bin64>vtune-self-checker.bat output log file.
0 포인트
yuzhang3_intel
중재자
6,667 조회수
Please post the output of the below command line as well, thanks.
C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64>amplxe-runss.exe --context-value-list
0 포인트
-Light-
초보자
6,657 조회수
The first time I run this command the output is as follows:
But the second time it says access is denied
0 포인트
yuzhang3_intel
중재자
6,624 조회수
Thanks for reporting the issue. We need to spend some time investigating it.
0 포인트
yuzhang3_intel
중재자
6,460 조회수
Can you please provide the CPU family/model information (run "set" command)? Thanks.
C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64>set
0 포인트
-Light-
초보자
6,459 조회수
0 포인트
응답
