I'm running a pretty straightforward openmp matrix multiplication example on Ubuntu 20.04 which fails when I try to run it with VTune, as shown below. Any ideas how to proceed?
wspear@yu:~/bin/tau2/examples/mm-nopie$ /opt/intel/oneapi/vtune/2021.1.1/bin64/vtune -collect performance-snapshot -app-working-dir /home/wspear/bin/tau2/examples/mm-nopie -- /home/wspear/bin/tau2/examples/mm-nopie/matmult
vtune: Collection started. To stop the collection, either press CTRL-C or enter from another console window: vtune -r /home/wspear/bin/tau2/examples/mm-nopie/r002ps -command stop.
vtune: Collection stopped.
vtune: Using result path `/home/wspear/bin/tau2/examples/mm-nopie/r002ps'
vtune: Executing actions 75 % Generating a report exception 'NoneType' object has no attribute '_get_as_query'
File "/localdisk/BB/INNLphep2l4r/b/tmpT2UjPi/build/build_release_posix-x86_64_icl_19.1.2_gnutools_6.3_binutils_2.28/reporter.python/src/python/tmpbu237__3/wrapper.py", line 96, in run
File "/opt/intel/oneapi/vtune/2021.1.1/config/report/summary.tmpl", line 107, in <module>
drawer = parser.create_drawer(adv_footer=adv_footer)
File "/localdisk/BB/INNLphep2l4r/b/tmpT2UjPi/build/build_release_posix-x86_64_icl_19.1.2_gnutools_6.3_binutils_2.28/perfconfigs/templates/common/tmphu7ca65z/common_summary.py", line 250, in create_drawer
File "/localdisk/BB/INNLphep2l4r/b/tmpT2UjPi/build/build_release_posix-x86_64_icl_19.1.2_gnutools_6.3_binutils_2.28/perfconfigs/templates/common/tmphu7ca65z/common_summary.py", line 243, in _create_child_drawers
File "/localdisk/BB/INNLphep2l4r/b/tmpT2UjPi/build/build_release_posix-x86_64_icl_19.1.2_gnutools_6.3_binutils_2.28/perfconfigs/templates/common/tmphu7ca65z/common_summary.py", line 288, in _create_section_drawer
File "/localdisk/BB/INNLphep2l4r/b/tmpT2UjPi/build/build_release_posix-x86_64_icl_19.1.2_gnutools_6.3_binutils_2.28/perfconfigs/templates/common/tmphu7ca65z/common_summary.py", line 321, in _create_tree_tt
File "/localdisk/BB/INNLphep2l4r/b/tmpT2UjPi/build/build_release_posix-x86_64_icl_19.1.2_gnutools_6.3_binutils_2.28/perfconfigs/templates/common/tmphu7ca65z/common_summary.py", line 237, in _create_query
File "/localdisk/BB/INNLphep2l4r/b/tmpT2UjPi/build/build_release_posix-x86_64_icl_19.1.2_gnutools_6.3_binutils_2.28/dicerhelpers.python/python/tmp3vbjshma/qlibrary.py", line 256, in append
AttributeError: 'NoneType' object has no attribute '_get_as_query'
vtune: Executing actions 100 % done
vtune: Error: 0x40000028 (Reporter error)
Sanity check:
wspear@yu:~/bin/tau2/examples/mm-nopie$ file ./matmult
./matmult: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=b48145f254a00cabd7529aadc5a211af1bfd47ca, for GNU/Linux 3.2.0, with debug_info, not stripped
We are not able to reproduce the issue.
Can you try to run the self_check.py script which will be available in <vtune-install-dir>/bin64. Please share the output with us so that we can validate it from our end.
self_check.py doesn't exist but here is the output of vtune-self-check.sh.
wspear@yu:~/bin/tau2/examples/LULESH$ /opt/intel/oneapi/vtune/2021.1.1/bin64/vtune-self-checker.sh
Intel(R) VTune(TM) Profiler Self Check Utility
Copyright (C) 2009-2020 Intel Corporation. All rights reserved.
Build Number: 613804
HW event-based analysis (counting mode)
Example of analysis types: Performance Snapshot
Collection: Fail
Instrumentation based analysis check
Example of analysis types: Hotspots with default knob sampling-mode=sw, Threading with default knob sampling-and-waits=sw
Collection: Fail
vtune: Error: Cannot start data collection because the scope of ptrace system call application is limited. To enable profiling, please set /proc/sys/kernel/yama/ptrace_scope to 0. See the Release Notes for instructions on enabling it permanently.
vtune: Warning: Hardware collection of CPU events is not possible on this system. Microarchitecture performance insights will not be available.
HW event-based analysis check
Example of analysis types: Hotspots with knob sampling-mode=hw, HPC Performance Characterization, etc.
Collection: Fail
vtune: Error: This analysis type requires either an access to kernel-mode monitoring in the Linux perf subsystem or installation of the VTune Profiler drivers (see the "Sampling Drivers" help topic for further details). Please set the /proc/sys/kernel/perf_event_paranoid value to 1 or less to continue without installing the drivers.
vtune: Warning: Access to /proc/kallsyms file is limited. Consider changing /proc/sys/kernel/kptr_restrict to 0 to enable resolution of OS kernel and kernel module symbols.
vtune: Warning: On some systems based on the Intel microarchitecture code name Nehalem / Westmere with C-states enabled, this analysis type may cause system hanging due to a known hardware issue (see errata AAJ134 in http://download.intel.com/design/processor/specupdt/320836.pdf). To avoid this situation, disable all "Cn(ACPI Cn) report to OS" BIOS options before sampling with VTune Profiler on such systems.
Example of analysis types: Microarchitecture Exploration
Collection: Fail
vtune: Error: This analysis type is not applicable to the current machine microarchitecture.
HW event-based analysis with uncore events
Example of analysis types: Memory Access
Collection: Fail
HW event-based analysis with stacks
Example of analysis types: Hotspots with knob sampling-mode=hw and knob enable-stack-collection=true, etc.
Collection: Fail
vtune: Error: To run this analysis, either set the Stack size option to the unlimited value (0 in command line), or provide access to kernel-mode monitoring with the /proc/sys/kernel/perf_event_paranoid value set to 1 or less.
vtune: Error: Unlimited stack size (0) not allowed in driverless mode.
HW event-based analysis with context switches
Example of analysis types: Threading with knob sampling-and-waits=hw
Collection: Fail
vtune: Warning: Context switch data cannot be collected in the current driverless mode if the kernel version is less than 4.3 or /proc/sys/kernel/perf_event_paranoid value is greater than 1. Update your system configuration for driverless collection or consider switching to the Intel sampling driver by setting an unlimited (0) value for the Stack size option.
vtune: Warning: VTune Profiler driver with insufficient permission is detected on the system.
vtune: Warning: Consider setting proper driver permissions (see the "Sampling Drivers" help topic).
vtune: Warning: Otherwise, the driverless collection with limited analysis support will be enabled by default.
The check observed a product failure on your system.
Review errors in the output above to fix a problem or contact Intel technical support.
Log location: /tmp/vtune-tmp-wspear/self-checker-2021.01.20_07.51.40/log.txt
I tried setting perf_event_paranoid, kptr_restrict and ptrace_scope to 0 and the check output became:
HW event-based analysis (counting mode) (Perf)
Collection: Ok
Finalization: Ok...
Report: Fail
Collection: Fail
HW event-based analysis check (Perf)
Collection: Ok
vtune: Warning: To profile kernel modules during the session, make sure they are available in the /lib/modules/kernel_version/ location.
Finalization: Ok...
vtune: Warning: Cannot locate debugging information for the Linux kernel. Source-level analysis will not be possible. Function-level analysis will be limited to kernel symbol tables. See the Enabling Linux Kernel Analysis topic in the product online help for instructions.
Report: Ok
Collection: Fail
Collection: Fail
HW event-based analysis with stacks (Perf)
Collection: Ok
Finalization: Ok...
Report: Ok
HW event-based analysis with context switches (Perf)
Collection: Ok
Finalization: Ok...
Report: Ok
Log location: /tmp/vtune-tmp-wspear/self-checker-2021.01.20_08.02.34/log.txt
However, my original test still fails in the same way:
vtune: Collection started. To stop the collection, either press CTRL-C or enter from another console window: vtune -r /home/wspear/bin/tau2/examples/mm-nopie/r000ps -command stop.
Done.
vtune: Using result path `/home/wspear/bin/tau2/examples/mm-nopie/r000ps'
Could you please share the result directory and cpu information.
Are you observed any issue during installation?
Also check the driver installation:
To verify that the sampling driver is installed correctly, please follow below steps:
cd <install-dir>/sepdk/src
./insmod-sep -q
This provides information on whether the drivers are currently loaded. Please share the observations.
There seems to be an issue with some of the drivers but I'm not sure how to address this.
wspear@yu:/opt/intel/oneapi/vtune/latest/sepdk/src$ ./insmod-sep -q
pax driver is loaded and owned by group "vtune" with file permissions "660".
socperf3 driver is not correctly loaded.
sep5 driver is not correctly loaded.
socwatch2_13 driver is loaded and owned by group "vtune" with file permissions "660".
vtsspp driver is loaded and owned by group "vtune" with file permissions "660".
I didn't notice any issues installing OneAPI, though I wonder if I somehow got a beta version by accident.
Results directory from an attempted run is attached.
CPU Info:
wspear@yu:~/bin/tau2/examples/mm-nopie$ cpuinfo
Intel(R) processor family information utility, Version 2021.1 Build 20201112 (id: b9c9d2fc5)
Copyright (C) 2005-2020 Intel Corporation. All rights reserved.
===== Processor composition =====
Processor name : Intel(R) Xeon(R) X5680
Packages(sockets) : 2
Cores : 12
Processors(CPUs) : 24
Cores per package : 6
Threads per core : 2
Based on those driver loading errors I unloaded the drivers with sudo ./rmmod-sep -s and then reinstalled them and then made sure I was in the vtune group (I hadn't been before). All of the drivers are listed as loaded now. However I get the the same final error as before when I run my test. The only change is this new error output showing up before the "collection started" message:
***ERROR: could not retrieve time stamp!
Warning: CPU_CLK_UNHALTED.REF_P includes an unrecognized modifier sample. Discarding modifier.
Warning: CPU_CLK_UNHALTED.REF_P includes an unrecognized modifier sa133000. Discarding modifier.
ERROR with Preparing core for Start (228)- Abort current run.
Event configuration failed - Aborting emon collection...
We are forwarding your case to Subject Matter Experts.
Could you please share the result directory for the analysis after loading the SEP driver.
Here it is. Thank you.
Hi Wyatt,
from your description I see that you are calling vtune with full path. Did you source the /opt/intel/oneapi/setvars.sh file?
I will check your results directory later.
best regards,
Heinrich
That's just the string I extracted from the vtune gui, which I tried out when my first command line efforts returned this error. setvars.sh is sourced in my .bash_aliases file. I get the same result invoking the vtune command without its path.
Wyatt
Hi Wyatt,
sorry for the long delay. there might be an issue with the vtune installation on Ubuntu 20.04. Colleagues have identified that some permissions were not right. If you have sudo rights you may try:
sudo chmod o+rx /opt/intel/oneapi/vtune/2021.1.1bin64/pinbin
this issues should be fixed in the next update of oneAPI.
best regards,
Heinrich
I was able to chmod pinbin but I still get the same error. Output directory attached.
Done.
Could you fix configuration file and try the collection again?
Replace VTUNE_INSTALL_DIR\config\analysis_type\include\common_events.xsl
<xsl:text>,CPU_CLK_UNHALTED.REF_P:sample:sa</xsl:text>
Should be
<xsl:text>,CPU_CLK_UNHALTED.REF_P:sample:sa=</xsl:text>
Thanks, Kirill
That change (adding the equals sign before the closing tag) didn't seem to make any difference. New output directory attached.
ok.
could you run a few simple collections?
/opt/intel/oneapi/vtune/2021.1.1/bin64/sep -dry-run/opt/intel/oneapi/vtune/2021.1.1/bin64/sep -start -d 1remove vtune drivers
cd /opt/intel/oneapi/vtune/2021.1.1/sepdk/src && ./rmmod-sep
/opt/intel/oneapi/vtune/2021.1.1/bin64/vtune -collect performance-snapshot -app-working-dir /home/wspear/bin/tau2/examples/mm-nopie -- /home/wspear/bin/tau2/examples/mm-nopie/matmultremove vtune drivers
/opt/intel/oneapi/vtune/2021.1.1/bin64/vtune -collect hotspots -knob sampling-mode=hw -app-working-dir /home/wspear/bin/tau2/examples/mm-nopie -- /home/wspear/bin/tau2/examples/mm-nopie/matmult
wspear@yu:~/bin/tau2/examples/mm-nopie$ /opt/intel/oneapi/vtune/2021.1.1/bin64/sep -dry-run
PMU type: Core (core)
Group 0:
INST_RETIRED.ANY: event id 2
CPU_CLK_UNHALTED.THREAD: event id 1
CPU_CLK_UNHALTED.REF: event id 0
CCCR
reg_type = 1 event_id = g reg_id = 38f reg_value = 700000000
reg_type = 1 event_id = g reg_id = 390 reg_value = 700000000
reg_type = 1 event_id = g reg_id = 3f1 reg_value = 0
reg_type = 1 event_id = g reg_id = 1d9 reg_value = 1800
reg_type = 1 event_id = g reg_id = 38d reg_value = bbb
ESCR
reg_type = 2 event_id = g reg_id = 1c8 reg_value = 0
DATA
reg_type = 4 event_id = 2 reg_id = 309 reg_value = ffffffe17b80
reg_type = 4 event_id = 1 reg_id = 30a reg_value = ffffffe17b80
reg_type = 4 event_id = 0 reg_id = 30b reg_value = ffffffe17b80
wspear@yu:~/bin/tau2/examples/mm-nopie$ /opt/intel/oneapi/vtune/2021.1.1/bin64/sep -start -d 1
CPU Event configuration failed - Aborting sampling run ...
Failed to verify PMU programming information
wspear@yu:/opt/intel/oneapi/vtune/2021.1.1/sepdk/src$ sudo ./rmmod-sep
[sudo] password for wspear:
Removing sep5 driver from the kernel ... done.
The sep5 driver has been successfully unloaded.
Removing vtsspp driver from the kernel ... done.
The vtsspp driver has been successfully unloaded.
Removing socwatch2_13 driver from the kernel ... done.
The socwatch2_13 driver has been successfully unloaded.
Removing socperf3 driver from the kernel ... done.
The socperf3 driver has been successfully unloaded.
No driver needs PMU arbitration anymore: the PAX service can be safely removed.
Attempting to stop PAX service ...
Removing pax driver from the kernel ... done.
The pax driver has been successfully unloaded.
PAX service has been stopped.
Done.
I assume the drivers only need to be stopped once.
wspear@yu:~/bin/tau2/examples/mm-nopie$ /opt/intel/oneapi/vtune/2021.1.1/bin64/vtune -collect hotspots -knob sampling-mode=hw -app-working-dir /home/wspear/bin/tau2/examples/mm-nopie -- /home/wspear/bin/tau2/examples/mm-nopie/matmult
vtune: Collection started. To stop the collection, either press CTRL-C or enter from another console window: vtune -r /home/wspear/bin/tau2/examples/mm-nopie/r001hs -command stop.
Done.
vtune: Using result path `/home/wspear/bin/tau2/examples/mm-nopie/r001hs'
vtune: Executing actions 19 % Resolving information for `kvm.ko'
vtune: Warning: Cannot locate debugging information for file `/lib/modules/5.4.0-65-generic/kernel/arch/x86/kvm/kvm.ko'.
vtune: Executing actions 19 % Resolving information for `matmult'
vtune: Warning: Cannot locate debugging information for file `/usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28'.
vtune: Executing actions 19 % Resolving information for `libittnotify_collector
vtune: Warning: Cannot locate debugging information for file `/opt/intel/oneapi/vtune/2021.1.1/lib64/runtime/libittnotify_collector.so'.
vtune: Warning: Cannot locate file `vmlinux'.
vtune: Executing actions 19 % Resolving information for `libiomp5.so'
vtune: Executing actions 20 % Resolving information for `nf_conntrack.ko'
vtune: Warning: Cannot locate debugging information for file `/lib/modules/5.4.0-65-generic/kernel/net/netfilter/nf_conntrack.ko'.
vtune: Executing actions 20 % Resolving information for `igb.ko'
vtune: Warning: Cannot locate debugging information for file `/lib/modules/5.4.0-65-generic/kernel/drivers/net/ethernet/intel/igb/igb.ko'.
vtune: Executing actions 75 % Generating a report Elapsed Time: 15.474s
CPU Time: 355.299s
Effective Time: 350.556s
Idle: 0.006s
Poor: 3.184s
Ok: 64.294s
Ideal: 283.072s
Over: 0s
Spin Time: 4.741s
Imbalance or Serial Spinning: 4.677s
Lock Contention: 0s
Other: 0.064s
Overhead Time: 0.002s
Creation: 0s
Scheduling: 0s
Reduction: 0s
Atomics: 0s
Other: 0.002s
Instructions Retired: 793,852,020,000
Microarchitecture Usage: 32.5%
CPI Rate: 1.540
| The CPI may be too high. This could be caused by issues such as
| memory stalls, instruction starvation, branch misprediction or long
| latency instructions. Explore the other hardware-related metrics to
| identify what is causing high CPI.
Total Thread Count: 25
Paused Time: 0s
Top Hotspots
Function Module CPU Time
compute$omp$parallel@102 matmult 229.687s
compute_interchange$omp$parallel@123 matmult 114.707s
_INTERNALd2589eef::__kmp_wait_template<kmp_flag_64<(bool)0, (bool)1>, (bool)1, (bool)0, (bool)1> libiomp5.so 4.344s
native_queued_spin_lock_slowpath vmlinux 2.388s
kmp_flag_native<unsigned long long, (flag_type)1, (bool)1>::notdone_check libiomp5.so 0.457s
[Others] N/A 3.716s
Effective Logical Core Utilization: 94.4% (22.655 out of 24)
Collection and Platform Info
Application Command Line: /home/wspear/bin/tau2/examples/mm-nopie/matmult
Operating System: 5.4.0-65-generic DISTRIB_ID=Ubuntu DISTRIB_RELEASE=20.04 DISTRIB_CODENAME=focal DISTRIB_DESCRIPTION="Ubuntu 20.04.2 LTS"
Computer Name: yu
Result Size: 240.0 MB
Collection start time: 16:11:16 19/02/2021 UTC
Collection stop time: 16:11:31 19/02/2021 UTC
Collector Type: Driverless Perf per-process sampling
CPU
Name: Intel(R) Xeon(R) Processor 980X series code named Westmere
Frequency: 3.333 GHz
Logical CPU Count: 24
Cache Allocation Technology
Level 2 capability: not detected
Level 3 capability: not detected
If you want to skip descriptions of detected performance issues in the report,
enter: vtune -report summary -report-knob show-issues=false -r <my_result_dir>.
Alternatively, you may view the report in the csv format: vtune -report
<report_name> -format=csv.
That's the first 100% I've seen. r000ps.tgz is the 3rd run, r001hs-log.tgz is the log directory from the last. Let me know if I should extract anything else. The whole r001hs directory is too big to include.
Looks like Westmere is too old for VTune. I'm not sure that it is still supported.
VTune drivers are not working here but driverless hotspots collection is ok.
I suggest using it and skip performance-snapshot here.
Probably you could try another server machine?
Is it hotspots analysis enough for you? What kind of problem you could catch here?
