What VTune analysis produces the DFLOP count for a given application? this would be extremely useful for efortlessly computing the GFlops,
TIA,
Giovanni
I am late with the answer,but anyway it is this counter FP_COMP_OPS_EXE.SSE_PACKED_DOUBLE.
There is no associated events to measure flops in predefined analysis. However you can find/use events in supported events, it depends on your using processor. For example, if you working on SandBridge processor, use:
# amplxe-runss -event-list | grep FP_COMP_OPS_EXE
FP_COMP_OPS_EXE.X87
FP_COMP_OPS_EXE.SSE_SCALAR_SINGLE
FP_COMP_OPS_EXE.SSE_PACKED_SINGLE
FP_COMP_OPS_EXE.SSE_SCALAR_DOUBLE
So, MFLOPS Formula = FP_COMP_OPS_EXE.X87 / 1x10e-6 / Elapsed Time
Using event FP_COMP_OPS_EXE.X87 directly in command line without VTune's predefined analysis, refer this article
For information about using FLOPS related events for your processor, read under VTune_amplifier_xe_2013/documentation/help/reference
"What VTune analysis produces the DFLOP count for a given application?"
I presume that DFLOP stands for double precision FLOPs.
Correct I am interested in Double Precision FLoating Point Operations therefore FP_COMP_OPS_EXE.SSE_SCALAR_SINGLE and FP_COMP_OPS_EXE.SSE_PACKED_SINGLE are of no interest to me. Furthermore, this PC seems to give the total FP_COMP_OPS_EXE.X87 that includes single precision, which is also not interesting to me. I only only want to measure Double Precision events.
How can I do that using VTune?
OK I found out how to do this. The solution is to create a new Analysis or custom analysis type and add those counters.
Cheers,
Giovanni
