Analyzers
5307 Discussions
Visual Studio / Game Engine / Vtune v8
cathode26
Processor Pentium 4 HT
I am a student and I am using Dr. Parberry's student made game enginecalled SAGE at http://larc.csci.unt.edu/sage/. When I try to run Vtune over it I get an assert error in the renderer.cpp. These are the steps thatI follow:
1)Open Sage Demo 6
2) Click on solution explorer
3) Right click on the solution and select add new item
4) Select the Vtune Performance Option
5) Select a Call Graph activity
6) Select dot.net
7) Select the executable
8) "checked" run activity when done
I have tried /fixed:no
So I get this assert error in the renderer, so I went and added some debugging statements that should give me some informationon theassert, but it appears as if it skips over the code and goes straight to the assert.
This code is supposed to create a file called example.txt and write yes or broke. But the file is not created when I run vtune over it. But the file is created when I dont run vtune with it. So I am thinking I am doing something wrong when I run vtune that there is some kind of starting address error. If there is anything anyone notices is wrong with how I ran vtune thehelp would be very appreciated.
Thanks Vincent
//---------------------------------------------------------Sample
int Renderer::cacheTextureDX(const char *filename, bool defaultDirectory)
// Check if texture already loaded
int slot = findTexture(filename);
if (slot > 0) {
return slot;
// set directory if requested
if (defaultDirectory)
gDirectoryManager.setDirectory(eDirectoryTextures);
// TODO: fix this sketch
// Fake allocate it
slot = allocTexture(filename, 1, 1);
// Replace with D3DX-loaded texture
textureCacheList[slot]->d3dTexture->Release();
HRESULT hresult = D3DXCreateTextureFromFile(pD3DDevice, filename, &(textureCacheList[slot]->d3dTexture));
ofstream myfile;
myfile.open ("example.txt", ios::app);
assert(myfile.is_open());
if(hresult == 0)
myfile << hresult + "yes ";
else
myfile <<
"broke "<
myfile.close();
//------------------------This is the Assert That dies
assert(SUCCEEDED(hresult));
return slot;
cathode26
I thought of another problem that could be
causing what appears to be a memory position
issue. There are two projects being compiled
in 1 solution.  So when I add new item,
from vtune I am only adding it to one of
the projects and then running the .exe.
Does anyone know if there are any special
configurations for multiple projects and
1 solution?  Or if vtune is just not capable
of multi projects?
-Vincent
//--------------  SOLUTION
For some reason vtune is looking in different
directories for files, like sound files, texture
files.  I was able to fix the problem by just
moving the files.
-Vincent
