Analyzers
5255 Discussions
Vtune Amplifier 2013: Function details
Aravind
I would like to obtain the following basic information using vune
  1. No of times a function is called
  2. The function call graph (also if possible, the detailed call graph with basic block info)
  3. No of times a statement is executed
I cannot find a way to do the same. When I looked on this forum, there are some methods given for older versions. But I cannot find the same for this version. Any help is appreciated.
Peter_W_Intel
1. There is no "exact" call count of function, only "statistical" call count which depends on samples
2. Similar function in Top-view report, like as call-tree. No basic block info is available.
3. No call count in statements.
Bernard
Valued Contributor I
Hi Peter!
Can you tell me how Vtune resolves an addresses to the function names.Does it use parsed IAT and Export tables.
Peter_W_Intel
iliyapolak wrote:
Hi Peter!
If your application was built with debug options like as "/Zi" "/DEBUG" on Windows to generate .PDB file, "-g" option on Linux to generate symbol info in binary. It is not difficult for any tool to find an (instruction) address to locate at a source line in a function.
Bernard
Thanks for answer!
I did not took into acount PDB files.
