Analyzers
5340 Discussions
Vtune Devcloud Admin Permission Issue
bxbxf
I am trying to use Vtune for my FPGA project and it gives me error with missing sampling drivers I have followed this guide
https://www.intel.com/content/www/us/en/develop/documentation/vtune-cookbook/top/configuration-recipes/vtune-profiler-server-in-hpc.html
and also found this message sent by @JaideepK_Intel on different topic but I don't have admin rights
https://community.intel.com/t5/Analyzers/VTune-Profiler-execution-error/m-p/1385175/highlight/true#M22180
The error message :
vtune: Error: Cannot start data collection because the scope of ptrace system call is limited. To enable profiling, please set /proc/sys/kernel/yama/ptrace_scope to 0. To make this change permanent, set kernel.yama.ptrace_scope to 0 in /etc/sysctl.d/10-ptrace.conf and reboot the machine.
vtune: Warning: Microarchitecture performance insights will not be available. Make sure the sampling driver is installed and enabled on your system.
In order to install the sampling drivers I tried to use command ./build_drivers inside the folder vtune/sepdk/src but the action requires admin rights. I copied this folder to my own directory. The build was done but this time I couldn't load drivers again admin rights issue
JyothisV_Intel
Good day to you.
We can see that you have posted more information with the same issue in another thread under Intel DevCloud with the link given below:
https://community.intel.com/t5/Intel-DevCloud/Devcloud-Vtune-Profiler-FPGA-Sampling-Drivers-Issue/m-p/1433265#M6692
Since, this is an issue is related to Intel DevCloud nodes, we will address this issue in the above thread and will stop monitoring this thread.
Jyothis V James
